| Non Reformed Meth Addict Feedback Score: 8 reviews
Car: '06 WRB My Stuff: Subaru Parts Fav Mod: A laptop, tuning software, and a little common sense. Location: Louisiana Posts: 3,178
IWSTI Addict since: Feb 2006 | MOD LIST ENGINE *Blouch Dominator 3.0r *Aquamist 2D water/meth system *Spearco TMIC *APS 65mm CAI *APS turbo inlet pipe *Perrin V1 billet rails(the ones with the steel braided lines) *Deatchwerks 740cc injectors *DIY TGV deletes *Ported and polished TGV housings *KSTech weldless TGV delete kit *Prosport UEL header and solid velocity stack UP *Injen catless DP *Greddy Evo2 *Hallman Pro MBC *Prodrive solenoid (currently not being used) *Cobb pulley *NGK one step colder plugs *Cobb turbo heat shield *Samco ancillary hoses *Perrin radiator shroud *Grimmspeed AOS *Optima battery *M1 Billet battery tie down *Port matched and blended intake manifold *Knike edged and port matched IC Y-pipe *Mocal 19 row oil cooler (Installed but waiting to be hooked up) *Mocal oil sandwich adapter (not installed yet-waiting on Primitive Racing skidplate) ENGINE MANAGEMENT *Cobb Accessport *Cobb Street Tuner software CHASSIS *JDM front bumper beam *GT-Spec fender cowl braces *Whiteline steering rack bushings *Whiteline front strut bar (not installed currently-won't fit with the Spearco-waiting on AWIC setup) *Cusco rear strut bar SUSPENSION *Cobb 24mm tubular swaybars *Cobb billet adjustable rear swaybar mounts *Kartboy endlinks *Tanabe GF210 springs(Swift R springs waiting for install) *Cut bump stops *Decent alignment(not the factory crap) *Bridgestone RE01-Rs *SuperPro rear trailing arm rear bushings *Tic (Not)Bangin' Rear End Tokico D-Spec rear struts w/remote adjusters *Front koni strut inserts DRIVETRAIN *Cusco engine and tranny mounts *TIC tranny crossmember bushings *TIC Klunk Killer Kit *Whiteline subframe lock bolts *Cobb short throw shifter *TIC Rear Klicky Kit *TIC shifter linkage bushings INTERIOR *JDM SWRT billet shift knob *Perrin billet dual gauge pod *Innovate wideband *Autometer boost gauge(until I get a nice set of gauges) *STI black floor mats *Forrester DIN pocket *ATI pod(waiting for the gauges) *Schroth Rallye3 four point harness(passenger side coming soon) EXTERIOR *4 Perrin wing stiffies for that all important rally look *Debadged trunk *Kuro-Buta RallyPig sticker on the mirror(gotta show some WRC heritage) ICE *Pioneer in-dash flip up DVD *Rockford Fosgate 10" sub(sitting on the garage floor at the moment) 18g plot with my own tune at 20.5psi. Last edited by Turbineguy; 03-10-2010 at 10:13 AM.. |
| | #2 |
IWSTI Addict since: Feb 2006 | Last edited by Turbineguy; 09-02-2009 at 07:57 PM.. |
| | #3 |
| HowTo Contributor Feedback Score: 2 reviews
Car: BMW Slow Build Fav Mod: BMW DD / Track Build Location: Outside Boulder, CO Posts: 3,138
IWSTI Addict since: Oct 2007 | Hmmm, no hits yet eh? Pics pics pics |
| | #4 |
| Professional STI Driver Feedback Score: 3 reviews | Sweet ride! Any dyno sheets to show the powerband? How about some pictures of the car? |
| | #5 |
| Spec C Club Feedback Score: 3 reviews Car: 05' AW WRX STi Fav Mod: Passport 8500 X50 Location: Illinois Posts: 1,081
IWSTI Addict since: Jun 2007 | interested in the plots with the 18G and Meth |
| | #7 |
IWSTI Addict since: Feb 2006 | Some mod list updates in post #1 and #2 has some new pics and vids. Currently running preturbo injection and an MBC. Next month I'm planning on a Blouch Dominator 1.0 and starting an air to water intercooler setup. I ordered an SP Engineering intercooler temperature meter and I'm putting it on the current Spearco to get an idea of pre and post intercooler temps and then will compare that to what the AWIC does. Dynamic Racing :: - SP Intercooler Temperature Meter Last edited by Turbineguy; 09-26-2009 at 09:17 AM.. |
| | #8 |
IWSTI Addict since: Feb 2006 | So I ended up going with a Blouch Dom 3.0r instead of the 1.0. Wanted some headroom for a built block later when this one eats itself. I'll tune it conservative for now to about 20-21psi which should be around 370-380whp with my other mods. I'm going to take a close look at the compressor on my 18g when it comes out to see if there's been any significant erosion from the preturbo injection. Didn't see any when it was out in April for the P&L AVCS/turbo line setup and intake manifold port matching. If there's errosion issues I'll take out the preturbo nozzle and speed up the AWIC process. I suspect I'll be the only guinea pig around running a Dom 3 through a stock location AWIC so we'll see how that goes. As the car was dynoed I was running 72% max on my IDCs so there's plenty of room there. I also may upgrade my turbo inlet pipe to APS and I plan on ditching the Perrin can for an Element to avoid the line size restriction. More to follow. |
| | #9 |
IWSTI Addict since: Feb 2006 | Dom 3 installed today. It's a really nice snail. Fit and finish are top notch and zero clearance issues. The only issue so far is it wants to hit 23psi regardless of where I set the MBC. I think it may be that the WG actuator might be set too high but I'm not sure yet. I'm also going to take the MBC apart and make sure it doesn't have something inside it gumming up the works. I'm leaning more towards the MBC being the issue. Going from an 18g to the Dom 3 I thought there would be a noticable increase in lag but there isn't much difference. The biggest difference is how the boost comes on. The 18g is like a light switch. Kinda like "wait for it...BAM". The Dom is much more linear. It builds smoothly to full boost without a real hard hit. Just keeps pulling harder and harder. Sounds nice too-alot like how a Supra sounds when it spools since they usually use Garrett BB snails (just alot bigger ). I'm shopping for a good turbo blanket that works with the internal gate. I found out my heatshield bracket is broken again. This is the third one that has cracked with the Cobb heatshield installed. I'll be assembling the bits for the AWIC and getting ready to install it soon. After that I'll be looking for a dyno session at COBB again to see what the result is.As for any errosion issues on the 18g from the preturbo injection there wasn't anything that could be seen with the naked eye. However I did notice that it doesn't look like there has been any fluid going to the second nozzle in the outlet of the intercooler. It looks like it's all been going through the preturbo nozzle. I have a feeling it's because of the pressure differential with the first nozzle before the turbo at less than atmospheric and the second one pushing against boost pressure. I've also had some issues with the nozzle in the IC getting gummed up over time with oil residue and losing flow capacity so I'm sure thats part of the issue as well since this particular nozzle has been in for nearly a year. Last edited by Turbineguy; 09-27-2009 at 08:45 PM.. |
| | #10 |
| Professional STI Driver Feedback Score: 1 reviews
Car: Blue/Black 05' STi Fav Mod: Stage II + Sparco Seat Location: Tallahassee, FL Posts: 430
IWSTI Addict since: Sep 2009 | any updated numbers? Did you install everything and not have it tuned, or what exactly did you do? |
| Thread Tools | |
