Go Back   IWSTI.com: Subaru WRX STI Forums > GD Series STi Discussion (2003/4-2007) > GD-Members' Journals
Old 08-02-2008, 02:02 PM   #71
Fav Mod: ECU
IWSTI Addict since: Apr 2007
Default Re: Gabedude's 07 STI project
I didn't bother with measuring PWC (what was the point, I already had the 99.5MM dropins). I did however split the block, mic every bearing to make sure they were within spec, etc. I honed the bores only with a cheap drill attachment. I get a tad, very small tad of piston slap. Once its warmed up it runs fine.
However, I inspected the Air pump cover plate and I did indeed put the right gasket on. The leftover gaskets I was thinking of were to the airpump pipe (from the head to the airpump).
So I guess I have to take the manifold off, the injectors, make sure the lines are all clean, then install the new intake manifold gaskets. If fueling is still the same, I am going to turn up the boost a bit and see if it levels out. At such low PW, it may be normal. It seems when I richen it up more, the oscillations are less. Its probably a multi-faceted issue.
Old 12-04-2008, 01:37 PM   #72
Account Closed For Now
Fav Mod: 05BLACKSTI
IWSTI Addict since: Mar 2007
Originally Posted by gabedude View Post
Got some work done last night. Called it quits around 11:30. Just gotta put on the intake mani, the turbo, and some accessories. Droppin it in today.
when you changed the timing belt did you change the tensioner's and the little pulleys that the timing belt goes around?
like in this picture:
Gates Timing Belt + Tensioner Kit, Subaru EJ25T WRX / STi 2006+
I was just wondering?
SUPERLOUDSTI is offline   Reply With Quote
Old 12-04-2008, 02:29 PM   #73
Fav Mod: ECU
Only one pulley was bad, tensioner was fine. Still running strong.
-Gabe
Old 12-05-2008, 12:37 PM   #74
Feedback Score: 3 reviews
My StuffSubaru Parts
Fav Mod: 6MT / 68HTA
IWSTI Addict since: Oct 2007
Send a message via AIM to XPT Tuning
Crank it up and get that meth flowing! I tossed my injectors in and finished up today. 60-65% IDC at redline now and got 0-1% trims on the first flash.
XPT Tuning is offline   Reply With Quote
Old 12-05-2008, 12:52 PM   #75
Fav Mod: ECU
Nice. It is all hooked up, need to install my new WBO2 sensor as mine took a crap.
Old 12-18-2008, 06:44 AM   #76
Car: Rd06 Sub Impreza 2.5
Fav Mod: Cosworth block, I wish
IWSTI Addict since: May 2008
Send a message via AIM to frshNAtSubie
where did you meet such a woman who loves such beautiful cars?!
Congrats man. Car sounds great.
frshNAtSubie is offline   Reply With Quote
Old 12-18-2008, 12:18 PM   #77
Fav Mod: ECU
At a party!
Methanol inj is finally working and I am tuning it now (just put 6k on dino oil (breakin) and switched to Rotella 5w40 synthetic).
Road dyno has me at a best of 393WHP and 398WTQ, but I think that is a bit on the edge for a road car. Gonna dial it down some to lower the EGTs.
Old 12-27-2008, 02:27 PM   #78
Feedback Score: 4 reviews
IWSTI Addict since: Aug 2006
Gabe when you pulled your engine did any of the timing covers crack? Were you able to reuse them?
OëT is offline   Reply With Quote
Old 01-18-2009, 02:38 AM   #79
Feedback Score: 1 reviews
Fav Mod: puting the HKS blowoff in the garbage
IWSTI Addict since: Jul 2007
hi gabe nice car u got there bro !
is it bad to do the break in of a new rebuild engine on fully synthetic oil ?
z38er is offline   Reply With Quote
Old 01-18-2009, 03:02 AM   #80
Car: WRX STI MY05
IWSTI Addict since: Dec 2008
Good approach
It is now possible to receive pleasure
SpeedGun is offline   Reply With Quote
Privacy Policy
