View Poll Results: What should I work on next (choose multiples if you'd like)?
Lap timer 30 25.00%
Temp gauges (low temps: intake, intercooler, ambient, underhood, etc.) 59 49.17%
boost (w/peak, etc.) 55 45.83%
boost ref ic spray 33 27.50%
EGT/Oil temp - mess with off the shelf senders (egauges sells them by themselves) 45 37.50%
Something else 15 12.50%
Multiple Choice Poll. Voters: 120. You may not vote on this poll
Old 06-19-2007, 12:00 PM   #161
Car: 06 Corvette (Z51)
IWSTI Addict since: Mar 2004
Send a message via AIM to Meridock
Default Re: the sti robot and his project accelerometer/thermometer/boost/kitchen sink thread
Originally Posted by fullerton
Why not just buy a laser thermometer for the tires/brakes?
cause I like non-typical gadgets... also since there is an element of logging here. it would be nice to be able to data dump a single source for data. ie jump out take 8 readings (logged) and jump in.
Meridock is offline   Reply With Quote
Old 06-20-2007, 05:31 AM   #162
Feedback Score: 3 reviews
Fav Mod: a garage
IWSTI Addict since: Sep 2005
Oil temp sender found:
http://www.egauges.com/vdo_indS.asp?...0F_US&PN=R8958
$15
M18x1.5 thread (this is correct for a galley plug right...if not they have a bunch of other sizes...and adapters)
operates from 33-240 Ohms
can read 140-320F
Using a voltage divider with a 100 Ohm resistor I can get a reading from 1.241 to 3.529 Volts. This means I can get about 468 discrete steps between 140 and 320F or much more than 1 degree F of precision, which is about what we need.
W00t for long, boring teleconferences.
Old 06-20-2007, 05:39 AM   #163
Feedback Score: 14 reviews
My StuffSubaru Parts
IWSTI Addict since: Oct 2005
I'll take $15 over a $260 gauge any day
Well, $115 or whatever for a multi-function gauge...
Mack is offline   Reply With Quote
Old 06-20-2007, 06:10 AM   #164
Fav Mod: a garage
^I will neither confirm nor deny pricing speculation
Old 06-20-2007, 11:02 AM   #165
Fav Mod: a garage
I contacted autometer, cyberdyne and issopro and got responses either directing me to contact someone else or with charts showing the resistance to temperature relationships. rock!
Old 06-20-2007, 11:12 AM   #166
ask for a job, too?
Old 06-21-2007, 08:56 AM   #167
Fav Mod: a garage
I should've but they aren't in atlanta and that's pretty much where we have a our heart set on living.
Old 06-22-2007, 02:54 PM   #168
Fav Mod: a garage
progress:
-improved spacing on the reading/peak readouts
-blink/beep to warn implemented. Right now the whole screen blinks, which is annoying and epilleptic. I need to make this better. (what about if on peak an LED flashed instead??)
-turn on in oil temp mode and once warm switch to next mode in line (and possibly beep) has also been implemented.
-also good news. I updated to the new version of the IDE and flash software and it saved 2k of code space on the chip! (means we can cram more features on it )
Old 06-22-2007, 05:01 PM   #169
i wish i knew how to do all this.
i was good at programming my TI-85 back in the day. I even had it show me intermediate steps in long formulas, so I could show my "work" on tests.
Old 06-22-2007, 08:17 PM   #170
Fav Mod: a garage
This thing is easier than that....its basically a limited bit of C code.
Privacy Policy
