| View Poll Results: What should I work on next (choose multiples if you'd like)? | |||
| Lap timer | | 30 | 25.00% |
| Temp gauges (low temps: intake, intercooler, ambient, underhood, etc.) | | 59 | 49.17% |
| boost (w/peak, etc.) | | 55 | 45.83% |
| boost ref ic spray | | 33 | 27.50% |
| EGT/Oil temp - mess with off the shelf senders (egauges sells them by themselves) | | 45 | 37.50% |
| Something else | | 15 | 12.50% |
| Multiple Choice Poll. Voters: 120. You may not vote on this poll | |||
| | Thread Tools |
| | #151 |
| Spec C Club Feedback Score: 3 reviews
Car: 04 STI Java black w/ Fav Mod: a garage Location: Just outside Manassass VA Posts: 1,804
IWSTI Addict since: Sep 2005 | a better idea of the sound tones: http://freesound.iua.upf.edu/samples...e.php?id=22684 Read the description |
| | #152 | |
IWSTI Addict since: Sep 2005 | Quote:
boost ref ic is later...boost first then ic spray later g-meter is set...changing this display is a preference thing OBD II and ecu splicing is completely nixed. | |
| | #153 | |
| The Next Petter Solberg Feedback Score: 0 reviews | Quote:
I think you will have 3 different senders for the temps so a simple bolt in would likely have distinct programming... I like the second display versus the one you chose for your alpha run. | |
| | #154 |
IWSTI Addict since: Sep 2005 | 3 senders... actually 2 - 1) does all the stuff from ic temps to ambient temps to whatever and works based on resistance 2) a generic oil temp sender in galley plug form. The programming should be the same. The circuit will be slightly different. Different resistors to "scale" the signal to 0-5V. |
| | #155 |
| Professional STI Racer Feedback Score: 3 reviews
Car: 05 WRB STi Fav Mod: TiC AST's - 7/6K Location: Chester, VA Posts: 633
IWSTI Addict since: Feb 2005 | STi robot - Good luck with the job search. I going to have to start that up soon, myself. |
| | #156 |
| Platinum Member Feedback Score: 14 reviews | definitely good luck. wish i could help you. |
| | #157 | |
I was thinking the "portable" one maybe different also since it would not normally be something you have a probe interface for. | |
| | #158 | |
| Platinum Member Feedback Score: 14 reviews | Quote:
Why not just buy a laser thermometer for the tires/brakes? | |
| | #159 |
IWSTI Addict since: Sep 2005 | BTW why is your title "less than or equal to some set denoted by the double-cross symbol" Meridock...if one wanted to one could have it attached to a longer wire...I'll leave it at that. The biggest consideration with a temp sensor is 1st what range does it operate over and 2nd what form factor is it. |
| | #160 |
| Platinum Member Feedback Score: 14 reviews | ASCII Shocker! |
| Thread Tools | |
