Go Back   IWSTI.com: Subaru WRX STI Forums > GD Series STi Discussion (2003/4-2007) > GD-General
Old 07-09-2009, 10:36 PM   #1
Car: 05 Subaru WRX STi
Fav Mod: None
IWSTI Addict since: Apr 2004
Send a message via AIM to STi_Boy805
Angry My 05 STi Runs 8 PSI
I have a 2005 STi with a CAI. Every once in a while, while in 3rd gear, my boost goes from the stock PSI (14.5 - 15) to 8 PSI.
i have no leaks and i dont get a check engine light or anything.
it continues to run at 8 PSI untill i disconnect the battery and then it goes back to normal.
has anyone heard of this before?
what do you think is wrong?
Thank You!
STi_Boy805 is offline   Reply With Quote
Old 07-09-2009, 11:10 PM   #2
Car: Aspen White 06 STI
Fav Mod: COBB CBE
IWSTI Addict since: Feb 2009
Default Re: My 05 STi Runs 8 PSI
What fuel are you using? Premium, I hope.
tnolan182 is offline   Reply With Quote
Old 07-10-2009, 05:14 AM   #3
Car: 08 STI
IWSTI Addict since: Jun 2009
CAI maybe making you run to lean when your boosting heavy and the ecu limps you.
STiLLawd is offline   Reply With Quote
Old 07-10-2009, 05:43 AM   #4
Feedback Score: 3 reviews
Fav Mod: THE WHOLE CAR!!!!
IWSTI Addict since: Jul 2008
second this!
seanforney is offline   Reply With Quote
Old 07-10-2009, 06:04 AM   #5
Super Moderator
Car: 08 DGM STI
My StuffSubaru Parts
Fav Mod: My wife :)
IWSTI Addict since: Oct 2003
Assuming there is nothing wrong with your boost gauge, the only thing I can think of is that you are experiencing enough knock to drop your IAM (ignition advance multiplier) below the boost disable threshold. This will cause you to run wastegate boost levels (wastegate duty cycle set to 0 - i.e. fully open). That would be why it returns to normal when you reset the ECU; you are resetting IAM and any fine learning knock correction.
I suggest you datalog your car or take it to a tuner. If your IAM is dropping that much then you're getting a serious amount of knock.
Old 07-10-2009, 07:08 PM   #6
Fav Mod: None
I always use Premium fuel. Here in california it's 91 octane.
What causes knock or what is it?
Thank u guys/girls for the imput.
I hope that with enough information I can fix this issue.
Thank you!
Old 07-10-2009, 08:28 PM   #7
Car: Black 07 STi
Fav Mod: Girlfriend...new lightweight model
IWSTI Addict since: Feb 2008
Knock is the sound signature of detonation in your combustion chamber. There are a number of things that can cause this. If you're getting enough of a rattle on the knock sensor to drop your IAM down that fast, it may be real knock or it may not. Get it checked out to make sure you're engine is in good health and your tune is ok (sounds like you're stock anyway). Failing that, definitely look into the possibility of a faulty or loose knock sensor. The vibration of a loose sensor will falsly signal knock events. Good luck!
ImranM847 is offline   Reply With Quote
Old 07-10-2009, 08:28 PM   #8
Feedback Score: 5 reviews
Car: PSM 05 WRX STi
Fav Mod: Good shoes
IWSTI Addict since: May 2008
The 8 PSI is the mechanical action of just the wastegate when the boost control solenoid is closed (not getting actuated)...
...it continues to run at 8 PSI untill i disconnect the battery and then it goes back to normal.
If the BCS is not getting actuated you would get the 8 PSI you are seeing. This could be caused by an intermittent contact somewhere in the BCS wire. But, the fact that you get ~15 PSI after resetting the ECU muddies the waters a bit
swr999 is offline   Reply With Quote
Old 07-10-2009, 10:44 PM   #9
Fav Mod: None
thank you guys/girls for the advise.
Im going to get my engine checked..
where do u think should do this.. Dealership? how much do you think it will cost.
Thanks.
Old 07-15-2009, 11:36 AM   #10
Car: 05 wrb Sti
Fav Mod: Oil change!
IWSTI Addict since: Sep 2008
dealership will rob u blind with fees cause they r a dealership and they just can lol simply said. go to a local Subaru shop if there is one in your area that had a high rep and a good quality shop.
bmoreSti is offline   Reply With Quote
Similar Threads
FS (NC/RTP Area): 05 STi 24K & 05 STi 60k Complete Part-out CyborgX_CZ Part Outs / Multiple Parts 62 12-30-2009 05:56 AM
Bigest Brake & Suspension Thread on Iwsti.com: All Subaru Makes Included JBK Performance.com Brakes/Suspensions/Stiffening 18 01-15-2009 04:54 PM
Subies versus Mitsubishes kumar Video Collection 30 12-27-2008 06:32 PM
:) DBA, Brembo, EBC, Hawk, Power Slot, Motul- In Stock JBK Performance.com Brakes/Suspensions/Stiffening 26 09-25-2008 11:42 AM
Privacy Policy
