Go Back   IWSTI.com: Subaru WRX STI Forums > GD Series STi Discussion (2003/4-2007) > GD-Technical > GD-Braking
Old 05-12-2009, 08:29 AM   #1
Car: 06 Subaru WRX STi
IWSTI Addict since: Aug 2006
Send a message via AIM to SteelDragonSTi
Default Brake light coming on and off
I just came back from the supermarket and noticed the Parking brake light come on. After a few seconds, it went off. This happened a few times. When I moved the car, depending on its motion, it would flicker on/off. I checked the fluids and they are on max. I checked for leaks and couldn't find one. I do have an aftermarket radiator overflow tank that did spill out some fluid, But I don't know what that has to do with the brake issue other than it being close to the metal brake line.
Any thoughts?
SteelDragonSTi is offline   Reply With Quote
Old 05-12-2009, 08:35 AM   #2
Feedback Score: 14 reviews
My StuffSubaru Parts
IWSTI Addict since: Oct 2005
Default Re: Brake light coming on and off
Are you referring to the parking brake light?
Mack is offline   Reply With Quote
Old 05-12-2009, 08:53 AM   #3
oops. Yes, the parking brake light. Sorry.
Old 05-12-2009, 08:59 AM   #4
Is the handle all the way down?
Old 05-12-2009, 09:01 AM   #5
Yes. All the way down, Fluids are on the Max line. No leaks.
Old 05-12-2009, 09:11 AM   #6
The parking brake does not use any fluids. It is a cable based brake.
If the handle is all the way down and there is nothing bent that would cause the hand lever switch to not contact correctly, you probably have a shirt somewhere. Possibly a bad switch.
Old 01-05-2010, 05:12 PM   #7
Feedback Score: 1 reviews
IWSTI Addict since: Aug 2004
mine did this too for a few days and now its gone. wierd.
normansti is offline   Reply With Quote
Old 01-05-2010, 05:40 PM   #8
Car: '06 Aspen White STi
Fav Mod: Myself
IWSTI Addict since: Jul 2005
PBR600RR is offline   Reply With Quote
Old 01-05-2010, 06:22 PM   #9
Car: Blue/Gold 08 Sti
IWSTI Addict since: Dec 2008
Pull the center consol apart and see if the pin (located at the base of the parking brake assembly) that activates the light is not damaged, also make sure the wire to that pin is connected properly. That switch or the wire to it is where the fault will be
skirkha3397 is offline   Reply With Quote
Old 01-17-2010, 10:31 PM   #10
Fav Mod: Q-RACK!!
IWSTI Addict since: Apr 2006
if you have a turbo timer etc then it could be that aswell, depends on how its wired
Privacy Policy
