| View Poll Results: Which one of these do you think makes the biggest improvement in braking distances? | |||
| Tires | | 46 | 52.87% |
| Pads | | 35 | 40.23% |
| Larger calipers | | 8 | 9.20% |
| upgraded brake discs | | 6 | 6.90% |
| Steel brake lines | | 13 | 14.94% |
| Brake fluid | | 9 | 10.34% |
| vehical weight reduction | | 12 | 13.79% |
| suspention | | 7 | 8.05% |
| other.....(please post) | | 0 | 0% |
| Multiple Choice Poll. Voters: 87. You may not vote on this poll | |||
| | Thread Tools |
| | #41 |
| Spec C Club Feedback Score: 0 reviews | Im not MGizzle, but ill give it a shot, basically, under extreme braking, the master cylinder moves, or more accurately, flex's in its brackets, which creates a inefficient transfer of energy, the M/C brace stiffens the M/C thus leading to a stiffer pedal feel and more efficient transfer of energy. |
| | #42 |
| S204 Racer Feedback Score: 0 reviews Posts: 3,498
IWSTI Addict since: Apr 2004 | Interesting, makes sense, thanks. |
| | #43 |
| The Next Petter Solberg Feedback Score: 1 reviews Car: 05 STi OBP Fav Mod: Data Acq System Location: Warren, Michigan Posts: 960
IWSTI Addict since: Jul 2006 | As far as the MC brace, bottom line is I did it because I hate our STi pedal feel. I want a brick for a pedal and the brace made the biggest difference. The SS lines were hard to feel at all but should work better when tracking as compared to stock. More firm pedal to me means less time to achieve the force I want at the brakes instead of it going to waste to other things like flexing the fire wall, booster etc. Alright, as far as the ABS unit having logic for tires that is a pretty broad statement. How can it know what you have on your car?? Impossible unless you tell it (calibrate it). The ABS unit reads differences in the 4 tires. If it is set to let go when it reads a 15% speed difference how is it going to get the most out of a R compound that can read 30% difference or 10% difference?? It can't. It is going to let go of the brakes when it sees what it has been calibrated to. This is set by the calibration engineers driving the crap out of this car and is mostly looked at during wet or icy conditions so dry is not the main concern here (unless it is calibrated for a sports car, which ours is and BOSCH has the ESP SPORT ABS unit on our cars supposedly). Again, the ABS unit is going to let go when it sees the difference it has been calibrated too. Yes, your tires can have the same difference as optimum but they could be way off as well. Again, look at tuner shoot outs vs. stock and look at the 60-0 or 100-0 numbers. R compunds might be better but you will laugh when you notice by how much the stock car looses. I have not see any comparison so far that has the stock car beat but supposedly there was with some WRX's in a tuner magazine where the R compounds have it beat. Also, you have to make sure that in that comparison they did use the ABS unit since to my knowledge a lot of guys runing serious R compound tires take the ABS fuze out since this way they can modulate the lock up of the tires and get better stopping (duuuhhh stickier tires). Anyhow, let me know if I am not making sense again. |
| | #44 | |
| S204 Racer Feedback Score: 0 reviews Car: '10 VW GTI Location: Montgomery, Al Posts: 3,299
IWSTI Addict since: Apr 2006 | Quote:
With the car at rest, have a buddy stomp on the brake pedal as hard as they can. Watch the master cylinder dance. This is translated through your pedal as slop. With the brace equipped and the car at rest, do the same thing. Watch as the master cylinder brace doesn't move. Basically, during threshold braking it makes the pedal feel more precise. The difference is really only felt when you're braking at 75% or greater. The difference is subtle, but but nice. | |
| | #45 |
| Spec C Club Feedback Score: 2 reviews Car: '05 CGM STi Fav Mod: The Driver Location: Beaverton, Or Posts: 1,806
IWSTI Addict since: Nov 2004 | |
| | #46 |
IWSTI Addict since: Nov 2004 | To throw something else out there, at what point does caliper flex start becoming an issue? I know when you start adding multiple pot calipers the open area on top will start flexing. Hense the reason for having 4 to 6 pads per rotor. It limits the open area and keeps the calipers more rigid. |
| | #47 | |||
| Junior STI Driver Feedback Score: 0 reviews Car: 05 Sti Location: Seattle, WA Posts: 138
IWSTI Addict since: Oct 2005 | Quote:
Is there some hidden logic that there is a maximum deceleration rate? I know for a fact this logic doesn't exist on the 05 STi ABS system, as I have had the unfortunate experiences of driving on snow and ice on the RE070's. All four wheels can be locked at speeds over 30MPH in less than one second - of course w/o slowing the car down at all. Quote:
Tuned Subaru WRX Cars vs. WRX STi Turning and Stopping - Road Test Comparison - Sport Compact Car Magazine The vishnu WRX with R-compounds (Toyo's not Kuhmos) stops just as fast as the stock STI, 12 feet shorter than stock WRX (greater than 10% improvement) and 8 feet shorter (7% better) than the other WRXs using the same stoptech brake kit. This is with all cars still using ABS, and in this case the lousy WRX system at that. So I still can't see how the ABS system is unable to account for increased traction levels of better tires - it has to be able to do this, traction is what its monitoring in the first place. | |||
| | #48 |
IWSTI Addict since: Apr 2004 | |
| | #49 |
IWSTI Addict since: Jul 2006 | seattle944t, that is actually the article I was thinking of too. 12ft better is not bad but I don't think it is all coming from R compounds. The vishnu car didn't only have R compunds, it had brake upgrades that in my opinion are necessary prior to going to R compunds (pads and rotors). Anyhow, I know where you are coming from and as in my previous statement it depends on how the ABS unit is calibrated. Some guys don't use tire variables in calibrating the ABS (of course difference in size and weight will effect this hence why throwing 20'' rims will hurt you and I am not talking about this) but if somebody is using tire data and in some cases the vehicle reference speed vs. the wheel reference speed than you are sort of screwed, no? You will deccel faster with the r compounds but it will let go at the deccel that was used during calibration. Again, it depends and you have to be careful. I am not sure how the BOSCH STi unit was calibrated and you could be right in that it does use the R compund max traction but my arguement is that we don't know this and in most cars this is something consumers don't know, hence you could hurt yourself depending on how it is done and what tire choice you make. And to stirr it up even more, we are talking "traction" differences in tires and not width, size, weight, inertia etc. Saying that "tires" will decrease your braking distance the most is a very very broad statement that can be as wrong as much as true depending on your choices. Anyhow, I shot an email to one of the ABS calibration guys who has been doing it for dozen of years and I am trying to find out the actual calculations used and what his opinions are on swaping tires (street to R compound) and its effects on a OEM ABS unit. I'll hit this thread up when I hear back from him. I wish I had a simulation software with ABS in it. |
| | #50 | |||
| Silver Member Feedback Score: 3 reviews
Car: Aspen 2005 STi My Stuff: Subaru Parts Fav Mod: Seat Time Location: Columbus, GA Posts: 2,049
IWSTI Addict since: Mar 2006 | Very interesting thread, but like seattle944t said, R-compounds are so much stickier than street rubber that they'd stop the car shorter even without ABS engaging. R-compounds at 9/10ths are still at least as sticky as good street tires, although I guess I shouldn't make that claim without data backing it up. However: Quote:
MGizzle- you mentioned Euro vehicles not need calibration because the tires are all so similarly good, but a lot of the same tires are sold here. This seems very contradictory to the rest fo your statements, since Europeans do run a wide variety of tires (winter to summer) just as Americans do. Could the various max-performance summer tires sold in America really vary that much? Dennis Grant has mentioned being able to brake better himself than ABS (on a car with R-compounds) in the dry, but not in the wet, which he suggests is due to the ABS having lost its calibration. But he also mentions Chrysler's data of ABS not braking at peak grip (for ANY car), perhaps because they calibrate for a less-than-perfect surface: DGs Autocross Secrets aka Autocross to Win Lastly, just subjectively, I hate ABS. This is my first car with it, and I always feel it engages too early. It probably isn't, but I'd love to, someday, actually measure for myself how much improvement it makes. I felt my Mazda6, even on its not-aggressive stock pads and no ABS, stopped quicker on good tires (but again, I have no data). Last edited by stretch; 05-13-2008 at 08:57 AM.. | |||
| Thread Tools | |
