Go Back   IWSTI.com: Subaru STI Forums > IWSTI Featured Members > The Fastest Times Forum
Old 08-18-2007, 11:09 AM   #1
Fav Mod: when it's not blown up
Default First time to the track with my new motor... finally in the 11's
60' 1.732
330' 5.099
1/8 95.23
1/8 7.753
1000' 10.039
1/4 118.67
1/4 11.956
24-25psi on 93+meth/water. I am still being a wuss with ignition timing. No avcs yet either. I think some more timing between 5-6k rpm will bring up my 1/4mi mph... maybe next week. I still haven't looked at the utec log from that run yet, but in one other log I saw it holding 24psi while spinning 1st gear off the line
I ran with the dccd in manual/open, launch control at 6k and ffs at 5.7k... lc was set to injector cut. Was shifting around 7200.
jays05 is online now   Reply With Quote
Old 08-18-2007, 12:15 PM   #2
HowTo Contributor
Car: 06 STi
Default Re: First time to the track with my new motor... finally in the 11's
Congrats on your 11 pass.
Have you dynoed this beast yet and if yes what type of dyno?
jasv11 is offline   Reply With Quote
Old 08-18-2007, 01:07 PM   #3
No dyno numbers yet, but I'm going to a dyno day at Moon Performance in Lake Placid NY next weekend. They have a Mustang Dyno. A friend is coming with his stock sti so we'll be able to make a good comparison. I tuned the car myself... UTEC on top of StreetTuner.
Old 01-04-2008, 07:36 AM   #4
Car: 04 sti
Fav Mod: SleepeR ModE
Send a message via AIM to hybooststi
You should leave the dccd set to auto. I have netted many low low 1. 6 60fts. With almost an identical set up. Minus cams and headwork. And bump up your lc a bit.
hybooststi is offline   Reply With Quote
Old 01-04-2008, 07:56 AM   #5
Car: 06 Aspen/gold STi
Fav Mod: Whatever I buy next
I see that the LC is using fuel cut, I was always under the assumption that ignition cut was safer and easier on the engine. Any reason you chose to cut fuel to the injectors instead?
C.J. is offline   Reply With Quote
Old 01-04-2008, 09:36 AM   #6
Fav Mod: CP35r 440whp
hi jay!!!!!!!!!
Old 01-04-2008, 06:39 PM   #7
Car: 04 sti
no , fuel cut is easier on the engine. also whats recommended. as far as ive seen from mjust about everyone else out there, but to each his own.
Old 01-04-2008, 06:40 PM   #8
Car: 04 sti
hey jay, what are you using for a boost control? mbc or electric?
Old 01-04-2008, 11:37 PM   #9
Car: O4 PSM Sti
Fav Mod: hYdRa
Send a message via AIM to STi-04
I was like wtf what track in NY is open now, then I realized kc bumped it from nowhere
STi-04 is online now   Reply With Quote
