Go Back   IWSTI.com: Subaru STI Forums > IWSTI Featured Members > The Fastest Times Forum
Old 07-12-2008, 02:20 PM   #1
Fav Mod: PPG GEARS
Send a message via AIM to xdrian
Default 12.006 @ 111
Went to englishtown the other day and ran a 12.006 @ 111 with a 1.7 sixty. im happy but could have finally made my 11.xx pass if i sneezed
STI MOTOR
PPG Straights
UTEC
Vf34
FMIC
Pump
Injectors
Meth Injection
LINK TO VIDEO vvvvvvv
SPP WRX 12.0 Pass - Video
xdrian is offline   Reply With Quote
Old 07-23-2008, 06:51 AM   #2
Car: CGM 05 STi
Fav Mod: seven kinds of smoke
Default Re: 12.006 @ 111
I was just curious. What did you do different between this trip to the track and the trip you posted in the other thread where you ran the 11.6xx? Did you add N2O, or adjust tire pressures? I'm getting ready to take mine to the strip for the first time and I know it wont be like my fwd car so I'm just looking around to see what works for other people. Thanks.
lawnmower22 is offline   Reply With Quote
Old 07-23-2008, 07:53 AM   #3
Car: Blue 06 STI
Fav Mod: FP Green
Send a message via AIM to rabbisti397
I would just leave the tire preasure as is. Also when you launch the car I would hold the throttle at like 5,500 rpms. Slip the clutch a little bit then dump it. The launch is the key to any good pass, that and not breaking and missing gears lol.
rabbisti397 is offline   Reply With Quote
Old 07-23-2008, 08:58 AM   #4
Car: Steel Gray 2006 STI
Fav Mod: E85
Send a message via Yahoo to roninsoldier83
Very nice run with a VF34!! The PPG gears are stock 5MT ratios right?
roninsoldier83 is offline   Reply With Quote
Old 07-23-2008, 01:34 PM   #5
Car: CGM 05 STi
Thanks for the instruction. I have been practicing my launch but I slip the clutch most of the way through first gear. I guess the trick is to get the slack out of the drive-train with the slip and then dump it huh? This practice is taking place on roads too, so it will probably all change at the track.
He has some better ones in the sticky.
