Go Back   IWSTI.com: Subaru WRX STI Forums > Owners' Lounge > FAQ/Newbie Forum
Old 06-06-2006, 07:07 PM   #1
Ben
Retired Admin
Fav Mod: Weight Loss
IWSTI Addict since: Dec 1969
Trader Rating: (12)
Send a message via AIM to Ben
Lightbulb Questions & Answers -- OFFICIAL THREAD
This thread is designed for "newbies" to ask questions or find answers. To ask a question, just post a reply to this thread and ask the question. When someone answers your question(s) the question and answer will be copied to the first post to make finding answers easier.
Before you post a reply and ask a question, please review the very first post (the one you're reading now) and see if the answer to your question is already here!
------ QUESTIONS & ANSWERS ------
Q: What is a Cobb Accessport?
A: An AccessPORT (known as AP) is a device that costs roughly $600 and flashes new maps (rewrites software on your car's ECU (computer)) to improve perfomance. In VERY basic terms, the AP makes your ECU tell the car to create more boost, which in turn, creates more power.
Q: What is Stage 2? etc.
A: Stage 1 is JUST the AP by itself; no other mods necessary. This is good for roughly 15-17 whp.
Stage 2 is the AP combined with a Turboback exhaust. This is good for roughly 40 whp (or an additional 20-25 whp over Stage 1).
Q: What is a protune?
A: A protune is when a professional tunes your car. This can be done using various software/devices, but a "protune" is most commonly done using an EcuTek or the AccessPORT. In the case of the AP, the pro tuner will make a special map (the software file the ECU reads) that is designed specifically for your car. This is good for roughly 20 additional whp over the "off-the-shelf" stage 2 AP map (assuming all you have is a Turboback Exhaust (TBE)).
Q: What is WHP?
A: WHP -- WHP is wheel horsepower, or "actual" horsepower after all drivetrain loss. While the STI has 300 HP, this is engine or crank HP, not wheel HP. Depending on the dyno, a stock STI has anywhere from 200-240 whp (approximately). Generally when talking about mods you express the increase in horsepower in WHP, as anyone that tells you a mod makes X HP at the crank is usually estimating.
Q: What is a Turboback Exhaust (TBE)?
A: A Turboback exhaust is a downpipe(3) + a catback exhaust(4) (or simply and exhaust that goes from the turbo all the way back).
Q: What is a downpipe?
A: A downpipe is a pipe that starts at the exhaust end of the turbo and goes from the engine bay down to the bottom of the car, meeting up with the center-pipe.
Q: What is a catback exhaust (CBE)?
A: A catback exhaust is an exhaust consisting of a center-pipe (or mid-pipe), a catalytic converter (cat), and a muffler (or tail pipe).
Q: Is there a diagram of the complete exhaust system?
A:
In the diagram above, the first piece is the downpipe. Next is the catylitic converter, however, this piece is commonly combined with the downpipe and is actually 1 piece. The third piece is the center-pipe (or mid-pipe) and finally there is the muffler (or tailpipe or axle-back exhaust).
Q: What is a wastegate?
A: The wastegate is a device that helps control the amount of boost the turbo creates. When the wastegate opens, boost is released. Any modification to the wastegate can cause serious problems, but the most common are:
1) using a different spring which makes the wastegate harder to open. This will cause the wastegate to open later and result in the turbo holding more boost. This is generally NOT recommended. If you want more boost, get an AccessPORT and do it safely.
2) "porting" the wastegate which makes the wastegate hole bigger and makes it easier for boost to escape. This is also generally NOT recommended but is used to solve problems in the rare case that are car is producing too much boost and there is no other way to control it.
Q: If I have an SPT catback, and want to jump to Stage 2, all I need now is just a downpipe & accessport flash, right? (my confusion comes from stating that the cat is sometimes combined with the dp, but then stated that it's part of the catback too).
A: The short answer to your question is YES. All you need is a downpipe and an AccessPORT flash to go Stage 2. As to your confusion, there are actually two catalytic converters on the STI. One is part of the downpipe, and the other is part of the midpipe. When we say "catback" exhaust, we mean coming after the cat in the downpipe, and as evilsti7 said, it should really be called a "downpipe back" exhaust.
Ben is offline   Reply With Quote
Old 06-06-2006, 07:09 PM   #2
Ben
Retired Admin
Trader Rating: (12)
The first question came from someone in a different thread:
Originally Posted by hoagie79
I'm a relatively new STi owner, had one for about 6 months but haven't started thinking about mods until now. And, I'm not ashamed to say, as I've been looking through some of these threads I have no idea what a lot of these modifications are. You guys use so many abbreviations and initials, that even that commonly-used-intitials thread doesn't completely clear things up. So....I'd like to propose a dictionary of mods presented kindergarten-style, like we're learning our ABC's for the first time, just that it's STi kindergarten. Please, don't provide definitions of things that just make them more confusing, just simple like: "a transmission transfers power from the engine to the wheels," as if we have absolutely no clue. And other newbies who are as confused as I am--I know you're out there--please don't be afraid to ask as well. It seems like the people on this forum are more than happy to help. So, I'll start off with a few ques.:
What is a Cobb Accessport? Stage 2?, etc., etc.
What's a Protune?
What are the downpipe and wastegate and how are these parts modded and how do these mods help with power/performance?
Thanks everyone!
Old 06-07-2006, 10:45 AM   #3
Fav Mod: Nintendo Decal
IWSTI Addict since: Apr 2006
...if I have an SPT catback, and want to jump to Stage 2, all I need now is just a downpipe & accessport flash, right? (my confusion comes from stating that the cat is sometimes combined with the dp, but then stated that it's part of the catback too).
unrequited is offline   Reply With Quote
Old 06-07-2006, 10:53 AM   #4
Car: 05 WRB/Gold
Fav Mod: Hood Scoop Homer
IWSTI Addict since: Jul 2004
yes. all you really need to run stage 2 is a downpipe, but running a turbo back exhaust (which is made up of a downpipe and a cat back exhaust) is fine too.
cat back is kind of misleading. almost every aftermarket sti downpipe ive seen has the cat placed pretty close to the turbo. so technically a cat back exhaust should be called a downpipe back exhaust, but they've been called cat back forever, so no one is going to change that.
Old 06-07-2006, 11:03 AM   #5
Car: 96 Outback Wagon
Fav Mod: Autobot Decal
IWSTI Addict since: Jan 2006
Trader Rating: (21)
Send a message via AIM to Einobaka
Yes, all you would need is a downpipe, but it's your choice weather you want a catted or non-catted one. The catback actually mates after the catalytic converter on a stock setup hence being called a "catback."
Edit: Evil beat me to the punch!
Einobaka is offline   Reply With Quote
Old 06-07-2006, 11:10 AM   #6
Thanks you two, this should be a great thread for nubs like me.
Old 06-07-2006, 12:15 PM   #7
Ben
Retired Admin
Trader Rating: (12)
The question (above) and answer (below) have been added to the first post.
Old 06-14-2006, 04:47 PM   #8
Car: Subaru powered Vanag
Fav Mod: Sponge Bob floor mats
IWSTI Addict since: Dec 2005
Question What's a sticky?
Hello,
Obviously I'm a newbie. I don't have an sti yet, but I'm doing the research for when I'm able to get one (please Lord, soon!!).
My question is, what exactly is a sticky and how do they work?
Thanks, Leo
bajaleo is offline   Reply With Quote
Old 06-15-2006, 10:35 AM   #9
IWSTI Addict since: May 2005
A sticky is just a thread that stays at the top of the forums. All "normal" or "non-stickied" threads will be sorted by date of most recent post. Sticky threads stay at the top regardless of most recent post date.
Moderators can make threads a sticky and remove their sticky-ness also. Typically these threads are 1) Of general interest to the population -or- 2) High traffic threads
gt9729b is offline   Reply With Quote
Old 06-23-2006, 03:31 PM   #10
Car: 05|WRB|STi
Fav Mod: Cobb Stage 2
IWSTI Addict since: Aug 2005
Send a message via AIM to SoaReS
Nice answer!
SoaReS is offline   Reply With Quote
Powered by vBulletin® Version 3.8.3
Designed & Powered by Domain Architect One of the largest message boards on the web !
