Go Back   IWSTI.com: Subaru WRX STI Forums > Owners' Lounge > FAQ/Newbie Forum
Closed Thread
Old 04-07-2005, 07:49 AM   #1
Car: 05 S4 Avant
IWSTI Addict since: Jan 2004
Default DCCD use
Ah, the dreaded DCCD discussion!!
Okay, so we all know what DCCD is (hopefully), with some of us even having that as a purchase consideration! But how many of us know how to effectively use it in manual mode?
This thread is for real-world examples of where you've successfully used the DCCD manual setting - what you were doing, what it was set to, and why you liked it.
I'll start.
In autocross, I've found that putting the DCCD on the bottom yellow (where the white line on the dial is exactly in top-dead-center) works really well. I believe this translates to a roughly 40-60 front-rear distribution.
I used to be religious about full-auto mode, but one day I had some extra runs and tried different settings. The first setting I tried was full rear. While this is fun for daily driving (getting the tail out easier), I found it was a little too tail-happy for autocross. I then tried one up from full rear. It was better, but still not good enough. On my next run, I did two up from rear, which is what I'm recommending here. It was still slightly tail-happy, allowing for throttle-on rotation, but it was extremely controllable. When sliding, I would drift almost sideways with the tail coming around very slowly. I'm really happy with this setting and will be using it from now on.
-Ollie
felonious is offline
Old 04-07-2005, 08:16 AM   #2
Spiteful Old Codger
Feedback Score: 1 reviews
My StuffSubaru Parts
IWSTI Addict since: Jul 2003
My initial thought was that manual would be better for autoX, but my times are better in automatic. My theory was that the car’s behavior would be more predictable and “conventional” in a rearward manual setting, but my experience has been that it’s not hard to learn how to use it effectively in auto. My approach has been to modify the suspension for neutrality and rotation and stick with the auto DCCD.
From a practical standpoint, I use the lock setting for loose surfaces and auto for most other situations.
I will continue to experiment with manual setting for racing, but auto seems like more of an asset than a liability to me.
sciolist is offline
Old 04-07-2005, 08:25 AM   #3
Feedback Score: 3 reviews
Car: Blue 2004 STi
Fav Mod: 2001 2.5RS Rally car...
IWSTI Addict since: Apr 2003
I stick with full auto and have become familiar enough with the algorithims that the car no longer surprises me. I guess I have turned myself over to the machine and let it do the thinking for me and I just put the car where I want it and let the magic happen. I tried the manual settings and they were definitely more predictable, but the extra half tenth or so that the auto setting gets me on corner exits has me sold. For most people I would recommend working with the manual setting until they know exactly what the car will do in every situation, then switch it into auto and start learning all over again and pick up a few more fractions. If you aren't that ultra competitive, leave it in manual and have loads of fun.
Daily driving I leave it in Auto. the only time I put it in lock is for messing around in loose surfaces or trying to make different shaped donuts :O
Xman is offline
Old 04-12-2005, 11:19 AM   #4
Feedback Score: 2 reviews
Car: AW 05 WRX STi
Fav Mod: Recaro Racing Seats
IWSTI Addict since: Sep 2004
Send a message via AIM to JKonquer Send a message via MSN to JKonquer
using manual dccd mode, is this bad for the car?
i notice that if you put the dccd setting on all the way rear, the differential makes clinking sound, the manual says its normal, but is it ok to drive everyday with manual mode?
JKonquer is offline
Old 04-12-2005, 11:28 AM   #5
Car: 05 S4 Avant
I drive in manual mode a lot, just not when making tight turns.
-Ollie
Old 04-12-2005, 01:10 PM   #6
Spiteful Old Codger
It’s fine if you can break traction – that’s what the DCCD is for. Just toggle back to AUTO when you come back to the grid or pit. Or, if you’re driving on the street, toggle back when you slow down and pull into a parking lot, or some other situation where you’ll be making tight turns with full traction.
sciolist is offline
Old 04-15-2005, 11:05 PM   #7
BOOST
Guest
Posts: n/a
Question
So I've gathered that my leaving it in lock for extended periods due to poor weather will not cause any harm... anything I should know about leaving it in lock?
Old 04-16-2005, 09:12 AM   #8
Car: 05 WRX STi CGM/Slver
IWSTI Addict since: Mar 2004
Don't use lock on paved roads unless it is really slippery (ice, snow). The other settings are supposed to be fine for daily use (although I wouldn't have it too close to lock when making tight turns on pavement). Leaving it on open (green box, dial all the way back) is fine for driving on pavement.
Pyrex is offline
Old 04-17-2005, 11:44 AM   #9
Fav Mod: Jr Tune FTW
IWSTI Addict since: Nov 2004
Every time I have heard of somebody breaking their rear axles, they were at the dragstrip (launching hard) with the DCCD in manual/full open. Having the DCCD in auto seems to be a lot safer for hard launches.
jays05 is offline
Old 04-18-2005, 08:21 PM   #10
Car: None...
IWSTI Addict since: Apr 2004
I've run my STi on snow with it in manual/full open. Rear end wanted to break away like crazy if you stepped on it. Of course, this is not the recommended setting. I was bored and wanted to try stuff out.
MeoW71 is offline
Closed Thread
Privacy Policy
