| Amateur STI Driver | Hey guys, so I’m finally ready to purchase an STI this weekend, I’ve been interested in the 04-05 as compared to the 03 and even the 06. Any difference in the 04 to the 05? Also I understand you can adjust the transfer case to rear wheel drive. Can you drive long distances in 2wd? Will this do anything in the long run; also can you change from awd to 2wd on the fly and vice versa? Thanks for any advice; I plan to be here for a while. Thanks This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #2 |
| Spec C Club Car: '05 CGM Fav Mod: HPDEs Location: Omaha, Nebraska Posts: 1,254
IWSTI Addict since: May 2006 Trader Rating: (3) | You'll definitely want to spend some time looking over the information on the following page. Newbie Threads of Interest Gary |
| | #3 |
| Senior STI Driver
Car: 05 PSMud STi Fav Mod: LWG map to fix overboosting Location: Richmond, VA Posts: 342
IWSTI Addict since: Aug 2007 Trader Rating: (0) | Are you from another country? I ask cause they didn't offer the STi to North America before 04. There is a list of differences between each year pinned in the newbie/FAQ section. You can adjust the power ratio from front/rear using the DCCD, but you can't make the car 2 wheel drive. |
| | #4 |
| Silver Member Car: 06 Subaru WRX STI Fav Mod: My 20g Location: Topsham Posts: 776
IWSTI Addict since: Jun 2006 Trader Rating: (7) | diddo on the newbie post. Just to answer some of you question hear. 1: No such thing as an 03' STI. 03' wrx yes STI no. They started here in 04' 2: No you can only bias more power to the rear or front you can not go full rwd. Depending on the rear of the STI depends on how much biasing you can do. Hope this helps. If you are about to buy one of these I suggest you know the car a little more. |
| | #5 |
| Silver Member
Car: 04 JBP STi Fav Mod: I do meth... Location: NJ Posts: 436
IWSTI Addict since: Nov 2007 Trader Rating: (4) | |
| | #6 |
| Gold Member
Car: '07 CMG STI Fav Mod: Not knowing how to "spell" hah Location: los angeles Posts: 3,917
IWSTI Addict since: Aug 2006 Trader Rating: (15) | ^ Yeah america 04 and on. Other countrys I'm pretty sure they've been around since the impreza has.. |
| | #7 |
| Amateur STI Driver | well thanks for the info upncummr ya i'm from this counrty i just did not know much about the subaru untill now. i've narrowed my search down to the 2004 STI hopefully buy the end of this weekend. |
| | #8 |
| Assistant to the Regional Manager
Car: 2005 Subaru WRX STi Fav Mod: Underglows Location: Tyler, Texas Posts: 8,874
IWSTI Addict since: Jul 2005 Trader Rating: (0) | Welcome. |
| | #11 |
| Junior STI Driver Car: Limited 07 Sti Fav Mod: bel rx65.....K BAND Posts: 51
IWSTI Addict since: May 2008 Trader Rating: (0) | i think you should read your manual because the dccd has nothing to do with how much power is to the front and to the back. its called driver controlled center differential for a reason....it controls your center differential or how much your car slips |
| | #12 |
| Gold Member
Car: 05 STi, 87 325e Fav Mod: ohlins w/RCE springs, sz55 Location: charleston Posts: 566
IWSTI Addict since: Nov 2005 Trader Rating: (1) | What by pulling the front axles out? Then somehow fooling the dccd into forgetting about the fron wheels? Yeah sure you can spend tons of money to make it 2wd but I don't think thats whats being asked. No you can't make the STi 2wd with the original equipment |
| | #13 |
| Gold Member
IWSTI Addict since: Nov 2005 Trader Rating: (1) | If you can get an 05 there were many improvements between 04-05 do some searching and reading there's plenty of info on this. The search button is your friend. |
| | #14 | |
| Senior STI Driver
IWSTI Addict since: Aug 2007 Trader Rating: (0) | Obviously yes it can be done. But we both know that was not what the OP was talking about. Quote:
I don't see why people have to try to be SO techincal on a non-technical question. | |
| | #15 |
| Junior STI Driver | get a 05!! This ad is not endorsed by this member. Please register or login to hide this ad. |
