Old 06-25-2008, 04:45 PM   #1
Car: 07 sti black baby !!
Default slight rattle when coasting in 1st and 2nd
Is anyones sti loud when coasting in 1st and 2nd gear i wanna say it sounds a little rattle when the cars in gear in first or 2nd and its moving it sounds fine .... this could be a normal thing with the sti because i just got mine and it only has like 3k on it... lemme kno if i should take it to the dealer or if its just normally like that ...... thanks ahead of time Dan
dans07sti is offline   Reply With Quote
Old 06-25-2008, 05:08 PM   #2
Default Re: slight rattle when coasting in 1st and 2nd
or it could be that the transmission is just loud lemme kno please !
Old 06-25-2008, 06:48 PM   #3
Moderator (v0.9 Beta)
Fav Mod: banhammer
Um, what does it sound like? Plastic? Metallic? Where is it coming from? What speed? What's the engine speed?
Old 06-26-2008, 04:29 AM   #4
Car: WRB 06 WRX STI
Fav Mod: Stage 2
Can't say for sure... but I'd say its just a normal rattle... Welcome to the STI!! I love my car but it rattles like a 72' pinto...
SonicBoom is offline   Reply With Quote
Old 06-26-2008, 01:19 PM   #5
in second gear when your not hitting the gas just letting the car coast in gear maybe 20 to 25 miles per hour if i had to say where it was coming from id say the underneath the front of the car i guess but its hard to tell !!!
Old 06-26-2008, 02:32 PM   #6
Fav Mod: Psh your mom
I understand we have two different cars. I have a 00' RS and you have an STI however, Id like to point out that in second gear whenever i hit 2000 rpm and i believe it to be the center diff. So maybe that may be it.
maverick326 is offline   Reply With Quote
Old 06-26-2008, 03:04 PM   #7
its only when im coasting though as soon as you hit the gas its back to normal any ideas ?..... I just got the car so i dont know if its normal or not
Old 06-26-2008, 03:24 PM   #8
Fav Mod: AP
My curiosity would keep me hunting in case it is something important. That being said, I've had my 07 for about a year and honestly and I don't pay much attention anymore. There's always something rattling or making noise. I just step on the gas and listen to the exhaust
Old 06-26-2008, 04:30 PM   #9
Im getting my exaust put on on thursday thank god !!!...... but this is deffenitly bothering me ... as soon as you hit the gas or press in the clutch to go to neutral it goes away its almost like its the motor thats holding the car back or something
Old 06-27-2008, 05:15 AM   #10
These cars are fully of rattles, noises, and other strange phenomena. It could seriously be ANYTHING, like a loose heat shield, or it may just be normal. FYI, the tranny/driveline does have some noise to it.
Old 06-27-2008, 09:32 AM   #11
I guess so ... I mean the car drives perfect so i dont know if i should take it to subaru or what
Old 06-27-2008, 10:10 AM   #12
Car: '08 335xi Coupe
Fav Mod: Dinan Reflash
There are a few things that rattle in the front of the car. Get under it and check the heat shields on the header and up-pipe as these can get loose and cause annoying rattles. Also, if the rattle is most pronounced after getting on it you could be hearing the waste gate flap. But I am betting that its a constant rattle and its just a loose heat shield. Nothing to worry about, just find it and clamp it down.
Old 06-27-2008, 10:15 AM   #13
but if it were a heatsheild wouldnt it rattle all the time this only rattles when im coasting without hitting the gas
