Old 06-25-2008, 10:22 AM   #16
Default Re: how much whp 04 sti stock?
thanks thats as good an answer as I can hope for
tim finnegan is offline   Reply With Quote
Old 06-25-2008, 10:25 AM   #17
Enginerd
Car: The Spaze Mobile
Fav Mod: Tuning
Originally Posted by boondocksaint View Post
Catted or not? 3.5", 3", or tapered? Pro tune or OTS map? Is it hot and humid on the dyno day, or is it cold and dry? Using 91 octane or 93 - or race gas?
I don't think we can even generalize without a little more input.
I'm so glad you said this.
The speculation of WHP and WTQ is absolutely ridiculous.
Old 06-25-2008, 10:50 AM   #18
Any suggestions where to go from here with modifications. I am interested more in reliability and longevity but would like some more performance as well.
Budget $2,000.00 for now
Old 06-25-2008, 10:53 AM   #19
Moderator (v0.9 Beta)
Fav Mod: banhammer
Downpipe, protune, done. You should have enough left over for sway bars.
Old 06-25-2008, 10:55 AM   #20
do you recommend a specific downpipe and sway bar set?
Old 06-25-2008, 11:00 AM   #21
Fav Mod: banhammer
Hard to say. There are LOTS of downpipe choices. If you want to keep the SPT exhaust, a COBB downpipe would probably be best as it should fit because it will taper.
Sways, well, I dunno. 24mm front and rear would be good. Get endlinks, too, at least for the rear. But that's another thread.
I advise you to do some reading. Use that search function and you'll have a lot of choices on your plate.
Old 06-25-2008, 11:46 AM   #22
any idea if putting in a cobb 3'' downpipe will require removal of the turbo?
Old 06-25-2008, 11:47 AM   #23
Fav Mod: banhammer
NO downpipe should require the removal of the turbo as far as I know.
Old 06-25-2008, 12:22 PM   #24
Car: Cgm 06 Sti
Fav Mod: Protune
Send a message via AIM to johannesfrans@yahoo.com
nope, I installed my helix dp without remove my turbo
johannesfrans@yahoo.com is offline   Reply With Quote
Old 06-25-2008, 12:30 PM   #25
Swollen Member
Car: 2004 PSM STi
Fav Mod: Dead hooker in the trunk.
Also depends on the altitude....
ToeKutter is offline   Reply With Quote
Old 06-25-2008, 06:21 PM   #26
Car: Blue 04 WRX STi
You should go with the turboback man...
Dstank is offline   Reply With Quote
Old 06-25-2008, 07:46 PM   #27
Fav Mod: ACPT driveshaft
I dyno'd my 2004 twice, both totally stock and on the same dyno, and both of the maps were provided by Subaru. The first one was the stock map when I got it in 2003 and the second was offered for the CA 91 oct issues - knocking, etc. Both on GST's mustang dyno in the Bay Area:
The stock tune 3/05:
http://i25.photobucket.com/albums/c6...r/STI_Dyno.jpg
After the reflash, +20whp +8wtq:
http://i25.photobucket.com/albums/c6...r/IMG_0330.jpg
AFR:
http://i25.photobucket.com/albums/c6...r/IMG_0329.jpg
HarlanPepper is offline   Reply With Quote
