Old 06-01-2008, 10:40 PM   #1
Default Thinking about buying an STI.....
i found a 2004 sti $14,000 white with 105K on the Odometer...claims to be in army and all highway miles...i know having an sti he probably ran it hard here and there so what do yall think? stay away or go all the way ....
Bill4458 is offline   Reply With Quote
Old 06-01-2008, 11:20 PM   #2
Friendlys Suby
Fav Mod: M&J Modified
Default Re: Thinking about buying an STI.....
Stay away.
Old 06-01-2008, 11:40 PM   #3
Car: 06 WRB/Gold STI
Fav Mod: Sticky-icky Tires
105K miles! I would stay away.
YeloFva is offline   Reply With Quote
Old 06-02-2008, 03:55 AM   #4
Car: 05' STi
Fav Mod: JDM Fogs
Why would you stay away....
If it is properlly maintained it will continue running strong as it was new.
I have 105K right now almost 106K on my 05' STi and have no problems. There are a bunch of STi's on here with over 100K still running strong.
I say go take a good luck at it, drive it, maybe have another STi owner with some knowledge go with you to take a look at it.
Old 06-02-2008, 05:10 AM   #5
Car: Blue 07 WRX STI
Fav Mod: Soap
Correct me if I am wrong, but I was under the impression that our turbos typically last 100k on average. The cost of replacement should be figured in for the turbo.
STI Sibb is offline   Reply With Quote
Old 06-02-2008, 05:23 AM   #6
Car: 05' STi
Fav Mod: JDM Fogs
The turbo could last longer. It depends on mods. Most people who are stage 2 will do a turbo around 100K or a little higher (I am going to do mine soon). There were members on here with 120+ on their stock turbo and mild mods.
The cost of a VF39 from the dealer is around 1K if I remember right. But the cost of a silghtly used VF39 from a member on here is around $400. So it's really not that bad to put a newer turbo on.
Old 06-02-2008, 08:23 AM   #7
replacing the turbo wouldnt be an issue....but is there anything inparticular i should look for with a higher mileage sti.... and yes i am going to look at it with an sti owner
Old 06-02-2008, 08:31 AM   #8
Moderator (v0.9 Beta)
Fav Mod: banhammer
Check the Used STi Buying Guide. It's a sticky in the General Forum, I believe.
On a higher mileage car, I'd request permission to do leakdown and compression tests on the engine. Check for fluid leaks, check the radiator for signs of patching. Make sure the car has all the equipment it SHOULD have. Etc.
