| Amateur STI Driver Fav Mod: Coming Soon Location: Brighton, CO Posts: 8
IWSTI Addict since: Mar 2008 Trader Rating: (0) | Would be curious to hear of any thoughts of any existing 2008 STi owners that spend some time in the snow. Item #1 upon acquiring one would be putting a snowboard rack on it as I'm driving over the passes about 2 times a month to go boarding. I'm used to driving a 7.6k pound 4x4 with all terrains in that stuff, so i'm curious about how a car half that weight, with AWD and non-all terrains manages it. thanks. This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #2 |
| Spec C Club Car: 06 STI, 08 GSXR 750 Fav Mod: 8cm 20g Posts: 1,330
IWSTI Addict since: Jun 2007 Trader Rating: (2) | If you put a set of snow tires on it and you'll do fine if not better than the truck. The only advantage the truck has is ground clearance but if you aren't going to bottom out the car it should out perform the big heavy truck. Definately don't try it on the stock tires because they are meant for street use only and you'll end up in a ditch real fast. |
| | #6 |
| STI Driver Car: 06 Subaru WRX STI Fav Mod: Headlight Adjustment Location: NC/Wi Posts: 292
IWSTI Addict since: Aug 2007 Trader Rating: (2) | This isn't needed. Just get a good set of snow tires or (i know i'm gonna get flamed for this) a good set of all season tires(not as good as snow tires but for snow but depending on how much snow driving you do, snow tires may not be worth it) and you will be okay. |
| | #7 | |
| STI Driver Car: Silver 05 WRX STi Fav Mod: POWER Location: Western Massachusetts Posts: 211
IWSTI Addict since: Nov 2007 Trader Rating: (0) | Quote:
| | #8 |
| STI Driver Car: 2006 Sti Fav Mod: Stage 2 Location: Auburn, Washington Posts: 264
IWSTI Addict since: Mar 2007 Trader Rating: (0) | I also have toyo all seasons because here in Washington we maybe see snow once or twice a year, but receive rain all the time. Snow tires are more expensive and wear very fast when driving on regular pavement all the time, so all seasons aren't a bad choice imo. |
| | #9 |
| The Hoff Fan Club, member #001 Car: 05 WRB/Gold Fav Mod: Hood Scoop Homer Location: Where ever The Hoff is! Posts: 10,373
IWSTI Addict since: Jul 2004 Trader Rating: (4) | With snow tires on the sti is VERY competent in the snow. Grab a set of 17'' rims and blizzacks (or your favorite snow tire), throw the dccd in lock and you'll be all set to get. This ad is not endorsed by this member. Please register or login to hide this ad. |
