Old 11-27-2007, 02:56 PM   #1
Car: 06 STi
Fav Mod: Cobb AP Stage 2
Send a message via AIM to 06silversti
Default Driving Noise
I get like a rumbling noise when I'm cruising at constant speed around 80 or 85. I pretty much read all the wind noise threads and thats at 120 and I'm not even near that. I can't figure out what it could be coming from but it sounds like it is coming from the back of the car somewhere.
06silversti is offline   Reply With Quote
Old 11-28-2007, 02:29 AM   #2
Car: 2007 STI Ltd UGM#164
Fav Mod: JDM washer nozzles
Default Re: Driving Noise
If you are running the RE070's, it could be tire noise. They get louder as they wear, and the faster you go.
emanteno is offline   Reply With Quote
Old 11-28-2007, 02:46 AM   #3
The Stig II
Fav Mod: EFI Logics tune
^^^ what he said. As my tires wore they made more noise.
jnprn2003 is online now   Reply With Quote
Old 11-28-2007, 04:43 PM   #4
Car: 06 STi
no its not that i am runnin Alpin 2 winter tires good thought though
Old 11-28-2007, 04:47 PM   #5
Car: White, 2004, STi
Fav Mod: 5zigen fireball resonator cutout
Send a message via AIM to hshdc04
Bad Bearing?...my back bearing was out and it sounded like the caliper was rubbing the brake pad at every rotation...but it was just the bearing...
hshdc04 is offline   Reply With Quote
Old 11-28-2007, 04:51 PM   #6
Car: 04 STI WRB/GLD
Fav Mod: HKS Carbon-Ti
^^^that would be my guess, I just replaced mine for the same thing a month ago.
2nedSTI is offline   Reply With Quote
Old 11-29-2007, 08:42 AM   #7
Car: 06 STi
I only have 4,xxx miles on my car do you think it would wear that fast or be defective?
Old 11-29-2007, 08:49 AM   #8
Car: '05 CGM
Fav Mod: HPDEs
Rather than a bad wheel bearing, I suspect the rumble is from your snow tires.
I get the same thing with the snow tires on my A4.
I think it has to do with the "open" tread pattern and the ripple pattern that is typical of snow tires.
Gary
Old 11-29-2007, 10:06 PM   #9
yea from where im from theres not a drop of snow all year....at all.........so i wouldnt know..but as far as the bearing..(if thats the problem)..then its probably defective cause im at like 84,xxx and the only reason mine went out is cause i had a slight run in with a 2 ft curb....haha
Old 11-30-2007, 06:44 AM   #10
Fav Mod: TBE
Yea snow tires make a lot of noise at high speeds. If you still have your stock wheels and tires throw them on and hit those speeds again. Then you can rule out the tires and focus on the bearings, axles, etc.
