Closed Thread
Old 11-01-2007, 11:51 PM   #1
Car: Black 07 WRX STi
Fav Mod: Cusco 2ZeroE Coilovers
Send a message via Yahoo to kolo11r
Default New To The Game
Just Bought an 07 sti payed off cash, Have 3 inch cobb turbo back exhaust, Cats cut off, cusco front rear strut tower braces and a cobb heat shield, getting m1 under body support frame, and cusco front rear sway bars, my stage 2 cobb access port arrives in a week, now i would like some good ideas on the next mod i should get to keep performance optimal! Thx for the help! Kolo
kolo11r is offline
Old 11-02-2007, 03:36 AM   #2
Zeb
Ninja Lurker
Car: '04 STi
Fav Mod: New Pavement
Default Re: New To The Game
Welcome. You came to the right place for info. Well, you've got the basics for both suspension and power, so ideas for next upgrades are going to vary from person to person. My ideas would be a; protune, gauges, short shifter with bushings. Just to name a couple. Have fun with your new baby. Read through the member journals if you ever need ideas for something. I think everything has been tried atleast once by someone on here.
Zeb is offline
Old 11-02-2007, 04:27 AM   #3
Welcome! I'd read up on modding w/o engine management especially since you nixed the cats...
boxtwo is online now
Old 11-02-2007, 06:55 AM   #4
Iron Fisted
Fav Mod: Sparco seat
Welcome. I would get that AP asap. Shouldn't be running a TBE (esp catless) w/o some kind of EM. Good luck on the mods.
amg destroyer is offline
Old 11-02-2007, 07:18 AM   #5
Car: 07 OBP/Gold STi
Fav Mod: DomTune & MD Whisper
Please don't drive your car until you get the AP... also, with the cats cut out I wouldn't drive it hard (get into high boost) until you get it professionally tuned. You have a lot of reading to do on running a TBE without a good tune (hint search blown 07 sti). Have fun, lol.
Welcome to the forum and enjoy the car!
Loubaru is offline
Old 11-02-2007, 07:30 AM   #6
Car: 05 Aspen White STI
Fav Mod: Defi Gauges
Send a message via AIM to STI_Mike
Welcome!
STI_Mike is offline
Old 11-02-2007, 07:36 AM   #7
Black Dragon STI
Car: 07 OBP STi 03WRB WRX
Fav Mod: My whole suspension
stay out of boost until you get a professional tune. 07s can overboost when you run catless, even with a Cobb stage 2 tune.
Draco-REX is online now
Old 11-02-2007, 03:34 PM   #8
Car: 07 WR Blue STI
LOl and we wonder why we see so many 07's blown. Like everyone said untill u get a tune by a professionla do not go into boost.
gOt_rally? is offline
Old 11-02-2007, 11:11 PM   #9
Car: 06 Aspen White STI
Fav Mod: Defi's
Get a tune! Bring a vid cam to the tuner so you can capture the moment. It'll be fun.
Iguana is offline
Old 11-04-2007, 04:22 PM   #10
hey thx for the heads up, im from sandiego area do u know of ne pro tuners around this area
kolo11r is offline
Old 11-04-2007, 05:09 PM   #11
Send a message via MSN to RFFG
welcome aboard...
tune =
RFFG is offline
Old 11-06-2007, 01:47 PM   #12
just got the stage 2 access port and a cobb short ram air intake with a protune! found the solution to the 07 STi over boost from running catless! if u dont want to get cats put on then read the following!
install two items from your local Subaru dealership. The first item is Subaru OEM part # 09535A060, which is a
replacement vacuum line where the restrictor pill will be located. The second item is Subaru OEM part # 22326KA120,
which is a new restrictor pill that has a center hole machined to 1.20mm or .047”. The total retail cost for both of these items
should be less than $6 USD. The restrictor pill will need to be carefully inserted in the middle of the vacuum line so the air
can pass through the restrictor pill. It does not matter which way the restrictor pill faces as longs as the machined hole is
perpendicular to the hose and air can pass through the pill.
HAPPY DRIVING HOPE THIS HELPED SOME ONE OUT!
kolo11r is offline
Old 11-06-2007, 01:55 PM   #13
Fav Mod: GT35R 450+WHP Pump No Meth
Where did you end up getting tuned at and what kind of numbers did you put down?
04STiguy79 is offline
Old 11-06-2007, 02:05 PM   #14
Car: 07 Subaru WRX STi
Fav Mod: Stage 2 :D
And by the way, getting caught here in Cali without a cat will land you a REDICULOUS fine. Competely not worth it.
holycow is offline
Old 11-06-2007, 02:14 PM   #15
Military! I have the car registered in Michigan so no cali laws apply, Pics Comming Soon
kolo11r is offline
Closed Thread
