Go Back   IWSTI.com: Subaru STI Forums > STi Technical Discussion > Exterior/Styling
Old 04-09-2006, 11:01 AM   #1
Fav Mod: FYI, I'm a dude
Default DIY: S203 style rubber underskirt
ok, so i didn't feel like paying over $100 for a v-limited rubber underskirt for my s203 cf lip. so, i decided to make my own with $19 in stuff from auto zone and home depot. you'll basically need to buy black garage door botton seal from home depot (~$9) and 15ft of 3m double side stick tape for side moldings from auto zone (~$10). make sure you buy the really sticky stuff.
here's a pic of the garage door seal. make sure you use the "hard" version of the rubber seal shown on the left and NOT the one on the right. the "soft" version will not hold up very well if you scrape it. (thanks to fourseasonsandles for the pic):
1st, cut the rubber door seal at the folded seam. i tried applying the lip without cutting it, but that section kept lifting off the lip.
2nd, clean your lip and the rubber door seal with some rubbing alcohol to remove dirt and oils. this ensures the tape sticks tightly. then start applying the tape to your lip. you'll need to cut out sections of tape to follow the contours of the lip.
3rd, remove tape backing and start applying the rubber seal. begin from the middle and work your way out toward the end. cut out wedges in the corners so you can bend the rubber seal. make sure you press hard afterwards so the tape adheres tightly.
trim off excess rubber seal and tape if needed.
that's it! easy cheap mod. looks pretty good too. should help to protect your lip a little from scrapes and such. great thing is that it's cheap to replace if it gets badly damaged. (fyi: the white stuff is foam called "great stuff." you can find it at any home improvement store.)
here's how it looks like from the front after application of the rubber seal/skirt
here's how it looks on the car
kevin
Old 04-09-2006, 11:16 AM   #2
Moderator Elite
Car: 2005 Subaru WRX STi
Fav Mod: Underglows
Looks very nice.
Old 04-09-2006, 11:21 AM   #3
Fav Mod: The Newest One!
Bout time someone came up with this! I waiting until I actually bought a lip to get working on it! Nice Job though!
Old 04-09-2006, 11:25 AM   #4
Moderator Elite
Fav Mod: Underglows
Added to sticky.
Old 04-09-2006, 11:32 AM   #5
thanks fellas! there's also several ways to orient the seal/skirt, so you can play around with it to find the one you like best.
Old 04-09-2006, 12:46 PM   #6
Send a message via AIM to jamolie
I was just at Lowes yesterday and couldn't find the rubber that you bought. I guess I'll have to head over to home depot to see if they have some of that stuff. Good job. It looks great!
jamolie is offline   Reply With Quote
Old 04-09-2006, 02:35 PM   #7
STI Master
Car: E46 M3
Fav Mod: ZCP Wheels
Trader Rating: (77)
looks great kevin...good idea!
Old 04-09-2006, 02:46 PM   #8
Car: 2008 Fitrari Red
Fav Mod: Getting 40mpg
+1 for creativity!!!!
Stee is offline   Reply With Quote
Old 04-09-2006, 03:19 PM   #9
Sold My Soul For Mods
Car: '05 CGM STi
Fav Mod: Track Time
Trader Rating: (14)
Nice idea! I might have to do that to my JDM lip when it arrives to protect the bottom from scrapes.
Old 04-09-2006, 04:50 PM   #10
the 3m tape is good too because it can be removed without leaving a residue if you want to reverse the process.
Old 04-09-2006, 04:54 PM   #11
HowTo Contributor
Car: 2008 DGM (BBS+Navi)
Fav Mod: stock FTL?
Looks great! I might have to do this to my V-Limited.
kts262 is online now   Reply With Quote
Old 04-09-2006, 04:58 PM   #12
Car: 08 MBC300 Sprt 4mtic
Fav Mod: RIP - 06 OBP STI
very nice!
Islandboy630 is offline   Reply With Quote
Old 04-09-2006, 06:05 PM   #13
Car: 2006 Steel Grey STi
Fav Mod: Invidia TBE
Send a message via AIM to SlvSTI05
looks a hell of a lot better than the real rubber skirt. Nice job man
SlvSTI05 is offline   Reply With Quote
Old 04-09-2006, 06:07 PM   #14
STI Master
Car: E46 M3
Fav Mod: ZCP Wheels
Trader Rating: (77)
I know Kevin, I have to say, thats very nice...
I dont think I feel like taking off the lip though
Old 04-09-2006, 06:18 PM   #15
i bet you can do it with it installed on the car...get dirty geaser ceaser
