| Junior STI Driver | I installed my invidia g200 last weekend and love it but i have an issue. The rear hangers (kartboy) do not hang straight down they are angled backwards. The muffler is also very close to the heatshield that hangs above the can, i pushed it out of the way but it still seems to rub. Of course all this would be fine if i didn't get an annoying little rattle at around 2500RPM (not sure exactly where its coming from). Is it ok for the hangers not to be verticle? And can i eliminate the heat shield above the can totally or would that melt my spare or something? I really don't see how i can adjust the exhaust and everything bolted right up with no leaks or anything ![]() ps. i am not using the stock dp and i removed the donut gasket and used a flange gasket. This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #2 |
| Spec C Club Car: '05 Aspen White STi Fav Mod: Fix-it tickets! Location: Sacramento, Ca Posts: 1,761
IWSTI Addict since: Apr 2007 Trader Rating: (5) | I think that you can remove those heat shields without any ill effects. I would try that because one may be loose somewhere. If that doesn't work, try some elongated exhaust hangars. |
| | #3 |
| Junior STI Driver | The other weird thing is that i had to trim my diffuser a bit. I thought the g200 fit without trimming This ad is not endorsed by this member. Please register or login to hide this ad. |
