Old 09-15-2007, 08:07 PM   #1
Default diagnose my idle problem please!
I've spent the last couple of weeks searching for an explaination for my idle problem and can only find threads about high idles or low idles or vacuum leaks or dirty MAF sensors. My problem doesn't seem to fit any of these scenarios and it's frustrating me.
My '05 STi is stage 2 and has been for about 6 months. Idle was fine before and after going stage 2 and the car ran great for a couple of months. About 2 months ago I noticed the car idling rougher and stop lights for no apparent reason. With the windows down you can actually hear what sounds like a miss but I don't get any CEL's and the engine never comes close to dying. The sound it makes when idling rough is kind of a "pup" sound.....
I know it's semi normal for it to do that once in a while, maybe every 15-20 seconds, but my car is now doing it about every 1-2 seconds. The best way I can describe it is "idle idle idle pup idle idle pup pup pup idle idle pup idle pup pup pup" it just sounds really lumpy and not very smooth at all. The entire engine vibrates and makes the car shake. You can also feel a sudden poof of air at the exhaust tip when it makes the miss sound.
Other than the idle the car runs great...very strong throughout the power band with no noticeable hesitation. I make full boost (up to 18psi) in 5th and 6th gears and it holds with no problems.
Should also mention that the car sometimes idles at about 800 rpm and feels pretty good with only the occassional miss sound. Most of the time though the idles settles in around 700 rpm and gets really lumpy.
Things I've tried to remedy the problem:
spark plugs, grounding mod, Techron injector cleaner, inspected vacuum lines and checked for boost leaks. Also cleaned the MAF sensor.
Current mods are Cobb turbo back exhaust w/cat, K & N typhoon intake, and AP V1. The rough idle was happening well before I installed the intake and I've also got a PDX e-tune for the intake. Idle problem was also happening when I was just running the Cobb OTS stage 2 91 oct map.
I'm seriously thinking about removing the exhaust and putting the car back to stock to see if it still happens, but I really don't think it has to do with the mods since it just started within the last couple of months.
Anyway, sorry for the long winded explaination. Hope somebody can help.
Thanks in advance.
chumpsteak is offline   Reply With Quote
Old 09-16-2007, 04:19 AM   #2
Default Re: diagnose my idle problem please!
Notice the colour of exhaust smoke at startup? like white/black?
itr_1211 is offline   Reply With Quote
Old 09-16-2007, 05:16 AM   #3
No white,blue,or black smoke at startup. Exhaust tip gets a little black around the end but it's always done that.
Old 09-16-2007, 06:47 AM   #4
Car: 2007 Subaru Impreza
Fav Mod: Cobb AP
What kind of plugs did you use? Did you gap them properly?
2MANYCARS is offline   Reply With Quote
Old 09-16-2007, 07:17 AM   #5
Replaced the plugs with the same as stock. gapped them to .028. The plug change didn't seem to make any difference good or bad.
I just got done pulling the intercooler again to check the turbo outlet and see if I could find any vacuum lines off under it, but after I put it all back together I still get the same crappy idle.
I popped the hood and watched the engine while it was idling and the engine seems to shake in sync with the "pup" noise, but I don't hear any pinging or any mechanical abnormalities....just the noise from the exhaust. I pulled a couple of vacuum line off while the car was running and it definately made it worse, so if it is a vacuum leak it must be really freakin small. I can't hear any vacuum leaks either.
Old 09-16-2007, 07:57 AM   #6
Black Dragon STI
Car: 07 OBP STi 03WRB WRX
Fav Mod: My whole suspension
This might be way off base, but it might be worth checking out anyways: Have you had a Compression/Leak-Down test done yet?
Old 09-16-2007, 08:04 AM   #7
No, haven't gotten to that point yet. Mainly because the car runs great once the rpms get over 1000 and I would think that the car would be burning more oil than usual if it was something like that wouldn't it? My oil consumption actually seems to be going down since the last oil change.
Old 09-16-2007, 08:18 AM   #8
Car: 06 STi CGM
Fav Mod: what you cant see :-D
hmmm, i think a protune will correct the issue, sounds like youre rich at idle
srt42sti is offline   Reply With Quote
Old 09-16-2007, 08:22 AM   #9
Would I be able to see that on a datalog? I was thinking about borrowing a laptop so I can datalog at idle and see what's going on. Does anyone have an experience with datalogging? Can I just use my Accessport cable and get some free software or something?
Old 09-16-2007, 09:33 AM   #10
i actually have the same exact problem, but have'nt realyl had time to start tearing into it. mine is on a protuned stage 2 07. it was fine up until about 3 weeks after the protune then this started so i have no clue yet to what it is. i checked all the lines on the engine and there dont seem to be any leaks but i'm thinking about taking it back up to the tuner to check it out.
20sti07 is offline   Reply With Quote
Old 09-16-2007, 10:58 AM   #11
Glad to hear I'm not alone with this problem.
I just got done removing the K&N intake and flashed the car back to stock with the Accessport. The idle problem is still there. I'm really not thinking it's a tune problem at this point.
Anybody else have any ideas?
Thanks for the input so far!
Old 09-16-2007, 11:15 AM   #12
Try resetting the ECU
Old 09-16-2007, 12:18 PM   #13
It's gone through many ECU resets since this problem started...most notably the negative battery terminal was disconnected for several hours while I replaced the plugs.
Old 09-16-2007, 03:53 PM   #14
Fav Mod: Me.....
maybe injector's??? IDK.... just throwing some ideas. :/
Old 09-16-2007, 05:28 PM   #15
I thought about this, but wouldn't I get a CEL if there was an injector or coil pack problem? I almost wish it would throw a CEL so I would at least have some idea of WTF is going on.
On another note I started pulling vacuum lines while the car was idling today and watched the boost gauge when I did. If I pulled small diameter lines the vacuum would drop a little, and when I pulled larger lines it would drop a lot. Obviously the engine ran like crap when I did this, but pretty much ran the same as my normal crappy idle, just intensified. Using this logic it would seem that I might have a very small vacuum leak. Does anyone have any good ideas on how to find a very small vacuum leak? I tried spraying some electronic cleaner around the different lines but didn't hear any change in engine rpms.
Also, can someone tell me what their stock boost gauge reads at idle? Mine pretty much sits at -.07 and fluctuates slightly.
