Old 06-02-2008, 02:17 PM   #61
Car: 07 STi Ltd
Fav Mod: ECU Tuning that I haven't done yet...
Unhappy Re: Cylinder 4 misfire?
I guess I'm next.
I noticed the car vibrating more on idle and minute later cruise started blinking along with Check Engine. P0304. :-( I drove it back to the house like a granny and everything seemed fine unless I stopped. My dealership is 150miles away. Is it safe enough to drive to them if I drive extra gentle? I don't want to spend any money on something that might turn out to be unnecesarry because I will have to take it to them anyway.
My car is BONE stock. 07 of course.
I didn't notice any extra smoke from the tailpipe but after reading this thread I cranked it up to check oil level and it was low and smoke was coming from underneath the oil cap. Not really big but kinda like you leave cigarette burning.
Oh men...
WaniuszY is offline   Reply With Quote
Old 06-02-2008, 02:26 PM   #62
Car: OBP 2007 STI
Fav Mod: Brake dust
Default Re: Cylinder 4 misfire?
Ouch... Sorry to hear that. How many miles do you have on your car?
Kamrulz4ever is offline   Reply With Quote
Old 06-02-2008, 02:33 PM   #63
Car: UGM 07 WRX STi
dang....im sorry. i would have never thought it would have happened to me.
starxidiam is online now   Reply With Quote
Old 06-02-2008, 02:49 PM   #64
Car: 07 STi Ltd
15k miles on it.
On idle engine rocks back and forth in the bay.
Old 06-02-2008, 02:58 PM   #65
Car: OBP 2007 STI
Fav Mod: Brake dust
Time to get it to the dealership, get her fixed. Make sure to get an EM this time.
Old 06-02-2008, 06:21 PM   #66
Car: 07 STi Ltd
This is the smoke coming out from my oil cap. Is this definitely mean that one rings are busted on a cylinder? Oil is hot. Maybe this is normal?
Video was taken right after killing the engin after it's been idling for 3 minutes.
Totally no smoke out of exhaust.
Oil Cap Video
Share your 0.02 please.
Old 06-02-2008, 06:31 PM   #67
Car: UGM 07 STI
Fav Mod: Driver
That's definately too much smoke. I didn't notice any when I did the exact same test a week ago. With the engine running, you can notice a puff or two every now and then in sunlight. I would get a compression test first.
atanarus is offline   Reply With Quote
Old 06-04-2008, 08:24 AM   #68
Car: 07 STi Ltd
Since I've got like 150 miles to my dealer, I will be doing compression test today replaing spark plugs at the same time and checking all connections to rule out something simple.
Will let you know how it went.
Old 06-04-2008, 08:40 AM   #69
Originally Posted by WaniuszY View Post
...Video was taken right after killing the engin after it's been idling for 3 minutes...Share your 0.02 please.
A little smoke coming out of the tube with the motor off doesn't tell you a thing. Take another video, this time with the car running at idle - have a friend rev the motor to 2K and hold it there. If a ringland is busted, it'll push a lot of smoke and pressure - if everything is OK, there will be a slight vacuum, with zero smoke.
Old 06-04-2008, 10:16 AM   #70
Car: 07 STi Ltd
I will do that right after work. Appreciate the input.
Will correct compression test definitelly eliminate possible ringland/piston damage?
Old 06-04-2008, 01:58 PM   #71
...Will correct compression test definitelly eliminate possible ringland/piston damage?
Absofrgigginlutely - that's why it is usually the first step in diagnosing a misfire problem. However, the smoke/puff oil tube test will tell you if you have a piston that isn't sealing properly, provided the breather system is nominal.
Old 06-04-2008, 05:09 PM   #72
Car: 07 STi Ltd
Default Rip: Infamous Cylinder #4 misfire - low on compression. :(
I don't need to check nothing no more. My jug #4 is officially low on compression.
Pass | Driv
135 45
142 130
Front Clip
BTW: They should've hang Moore before he wrote his laws. The infamous Cyl #4 is pain in the A to get to. I have shop service manual for 06 STi and it says about removing battery and windshield asher reservoir. Well in 07s above mentioned tank is at the front clip so taking it out won't help. It's soo hard to take the coil pack out because there is VERY little space between the engine block and the frame. You have to use the fact that coil pack's tube is made of rubber and need to make it;s way out forcing it a little.
Old 06-04-2008, 05:45 PM   #73
Car: 07 STi Ltd
Wonder how long it will take the dealer to fix it. I can't live without my car......
Old 06-04-2008, 06:03 PM   #74
Car: 06STi
Fav Mod: Humiliated n00bs
I just got my 06 back with a new stock short block and heads after a constant P0304 and low compression in that jug (32kmi under warranty).
Took the dealership 2.5 months to rebuild the motor. I don't think thats what you wanted to hear but thats the reality. BTW I took that loaner and beat the living crap out of it every single day out of anger.
Mexitr0n is offline   Reply With Quote
Old 06-04-2008, 06:27 PM   #75
2 and a half months? Boy, did they put you on the back burner or what? That's a 1 day job for 2 good mechanics.
If that had been me, the loaner would've come back in chunks.
