Old 04-13-2008, 12:06 PM   #16
Trader Rating: (14)
Default Re: Cylinder 4 misfire?
when you get a good compression AND leakdown test and it still throws a code, it could be a spark plug, coilpack or injector. So only one of those three. Good luck man.
blindfold is online now   Reply With Quote
Old 04-13-2008, 12:16 PM   #17
Car: 06 STI, 08 GSXR 750
Fav Mod: 8cm 20g
might as well throw in new plugs when they do the compression test too.
Hitman83 is online now   Reply With Quote
Old 04-13-2008, 05:35 PM   #18
Car: UGM 07 WRX STi
what kind of plugs? and how much you think a compression and leakdown test will cost?
starxidiam is offline   Reply With Quote
Old 04-13-2008, 05:37 PM   #19
Fav Mod: 8cm 20g
OEM plugs are fine and a leakdown/compression test will run around $100-$200 depending on where you go
Old 04-13-2008, 05:43 PM   #20
Car: UGM 07 WRX STi
o ok. the dealer is about an hour away though, theres gotta be a way to get OEM plugs easier.
Old 04-14-2008, 06:36 AM   #21
Car: UGM 07 WRX STi
i could be paranoid, but the car felt realyl weird. it wouldnt realyl go like it used to, it kinda bucks a very little bit. it doesnt hit full boost. like 16.something and it just seems slower. so idk what happened. ill let yall know the resuilts of the test.
Old 04-15-2008, 03:09 AM   #22
Car: UGM 07 WRX STi
yup just as i suspected, the guy told me something in cyl 4 is messed up, a ring the piston, idk. he didn't charge me for the test though. im going today to the dealer. is there anything i should do prior to going? when i uninstall AP will it go back to stock mode? or do i need to re flash to stock mode then uninstall?
Old 04-15-2008, 08:59 AM   #23
Fav Mod: CAR LIFT & Protune!
mine was an injector... it was acting all crazy, this was a few months back.
wow, that sucks man, sorry to hear. hopefully they will hook you up good.
yeah, unmarry the AP and it will be on the stock ECU (make sure you do this!!!) otherwise you will be on your own! i would leave the cobb stickers, they cannot void your warranty for cobb stickers.. just make sure you dont have the AP in the car. good luck
Old 04-15-2008, 04:56 PM   #24
Car: UGM 07 WRX STi
i don't know where to start a new thread, but just as i suspected when i took it to the guy we know he did the test and told me that it was definetley a piston ring or something broken in that cyl 4. so i took it to the dealer after i uninstalled AP and emptied my car out. and they said ok we will take a look at it tomorrow morning. so i guess im in for a long ride with no car...just like the other 07 owners.
Old 04-15-2008, 04:58 PM   #25
Fav Mod: 8cm 20g
good luck and please keep us posted. if they say "NO" call up SOA and demand a new motor.
Old 04-15-2008, 06:37 PM   #26
Car: UGM 07 WRX STi
do i tell them the whole situation at SOA, how would i start the conversation? im not good with these kinds of things.
Old 04-16-2008, 12:21 PM   #27
Fav Mod: 8cm 20g
I wouldn't tell SOA anything they don't need to know, ie accessport, launching etc. If the dealer denies the warranty just call them up and demand they honor the warranty on your stock car. Threaten to take them to court and fax them a summons if they say no. Definately try the nice guy approach first but you may need to fight it depending on what the dealer tells SOA when they deny the warranty.
Old 04-16-2008, 12:59 PM   #28
Work with the dealer first - going to SOA is a last resort.
Old 04-16-2008, 02:26 PM   #29
Fav Mod: 8cm 20g
+1.
I've had to deal with SOA twice so far. Both times I called SOA and they took care of it immediately. SOA isn't always the enemy but the dealer is from my experience
Old 04-16-2008, 05:25 PM   #30
Car: UGM 07 WRX STi
still no call from them, I'm calling tomorrow and asking them whats up.
