Old 08-30-2007, 07:01 AM   #16
Car: 06 STi WRB
Default Re: Gold heat reflective foil on IC piping?
^OFF TOPIC but fullerton I too have a big TMIC and I noticed that you haven't removed the rubber seal around the splitter. i recommend doing that. It limits the amount or IC used with in coming air. I have noticed a bit of a difference and the car feels as though it breathes better. It's held on by lil black plugs just like the weather stripping on our hoods. DO IT!
Tbagger is offline   Reply With Quote
Old 08-30-2007, 07:04 AM   #17
abracious
Fav Mod: Track time
I already have, and replaced it with a new seal, as can be seen in the pict above. Without the seal, air will take the easiest route, which is NOT through the TMIC, but around it. I'd recommend you add that seal.
Old 08-30-2007, 07:05 AM   #18
Car: 06 STi WRB
^ya I'm retarded. I noticed you did that after I went back to the pics.
<======= DUMB.
I have a similar seal around that. GO GARAGE DOOR GUARD!!!
Old 08-31-2007, 05:35 AM   #19
Fav Mod: LS6 and T-56 swap :D
Looks like I'll first try wrapping the cold-side piping. This stuff looks to be pretty effective although it indeed is kinda too bling. But if it works on McLaren F1, it should be good, right?
Rookie84 is offline   Reply With Quote
Old 09-01-2007, 11:52 PM   #20
Car: aspen 2005 wingless
been there, done that, got the t-shirt
it works. doing cold side piping this week.
Old 09-02-2007, 04:50 AM   #21
abracious
Fav Mod: Track time
is the gold stuff only adhesive backed foil? the aluminum stuff is foil-fiberglass insulation-adhesive.
Old 09-02-2007, 06:12 AM   #22
Car: 07 WRX STI
Fav Mod: Matching Dead Pedal
Send a message via Yahoo to cpunlamd
Im sure the foil works well. But its so FUGLY!
cpunlamd is offline   Reply With Quote
Old 09-05-2007, 09:03 AM   #23
Car: 05 WRB STI
Fav Mod: rear sway bar
the gold is also insulated.
2superblus is offline   Reply With Quote
Old 09-05-2007, 09:26 AM   #24
abracious
Fav Mod: Track time
good to know.
Old 09-05-2007, 10:28 AM   #25
Car: 2004.5 Subaru WRX ST
Fav Mod: 17x10s
Done a while ago:
Stock heat sheild:
Intercooler + pipes:
Also, now have the gold coating my Cusco sheild which overlays the factory turbo heatshield, as well as on my K&N typhoon heatsheild. 97% of it isn't visible anyway, but it's bound to be effective.
loworbitSI is offline   Reply With Quote
Old 11-30-2007, 12:01 PM   #26
Fav Mod: when it's not blown up
Yeah um I got a little carried away last night...
Old 11-30-2007, 12:03 PM   #27
Wheel33tist Whore
yes you did.....
Old 11-30-2007, 02:02 PM   #28
Car: 07 OBP/Gold STi
Fav Mod: DomTune & MD Whisper
now you got to get a gold grill to match that ****!
Loubaru is offline   Reply With Quote
Old 11-30-2007, 02:03 PM   #29
abracious
Fav Mod: Track time
wow! i tend to agree with clap's statement!
Old 11-30-2007, 05:49 PM   #30
Trader Rating: (14)
I did the tube wrap from Summit, it was about 50 bucks or so, works well too.
Thermo-Tec Cold Air Tube Heat Shield
