Old 05-30-2007, 01:33 PM   #1
Car: 04 STI WRB/GLD
Fav Mod: HKS Carbon-Ti
IWSTI Addict since: Apr 2007
Default Boost question?
I tried searching and it pwned me Anyhow, what psi whould a stock 04 STI be running? I have a very high pitch whistle at boost, and Im pretty sure that it is due to a leak........just wondering if I am losing power due to this leak??? Thanks
2nedSTI is offline   Reply With Quote
Old 05-30-2007, 01:59 PM   #2
Car: 04 STI WRB/GLD
Default Re: Boost question?
sorry mods, thanks for moving
Old 05-30-2007, 02:58 PM   #3
Car: 07 OBP WRX-STi
Fav Mod: Girl in the backseat
IWSTI Addict since: Oct 2006
should hit around 14.5 psi peak then tapers down.
TuffStuff is offline   Reply With Quote
Old 05-30-2007, 03:03 PM   #4
Car: Da Name sez it all
Fav Mod: Squeeky brakes -.-"
IWSTI Addict since: Nov 2005
Do you have any mods?
SubaSTi04 is offline   Reply With Quote
Old 05-30-2007, 03:35 PM   #5
Car: 05 WRX STi (wrb/gold
Fav Mod: Utec
IWSTI Addict since: Jul 2006
yeah 14.5 any bov. or tbe.
nasti05 is offline   Reply With Quote
Old 05-30-2007, 03:38 PM   #6
Car: 04 STI WRB/GLD
car is completely stock, to the best of my knowledge anyhow..
I am only seeing 7.5 psi steady!!! What the hell! What do you guys think could be the problem here?
EDIT: I did the silencer delete mod, thats it.....stock exhaust, diverter, etc.
Old 05-30-2007, 03:43 PM   #7
Fav Mod: Meth
IWSTI Addict since: Nov 2006
you may have a boost leak somewhere..
Flipn is offline   Reply With Quote
Old 05-30-2007, 03:50 PM   #8
Car: 04 STI WRB/GLD
I think that I read somewhere that the high pitch squeal that I am hearing is caused by a leak, is this true? Also, where are the most common places for the leak? I am going to go out and look at the car again to see if I notice anything. Thanks for all the help so far.
Old 05-30-2007, 03:54 PM   #9
Car: 2005 OBP STi
Fav Mod: CBE
IWSTI Addict since: Aug 2006
check all your vaccuum lines and the inlet for leaks. if you dlnt visually see anything, get a can of carb cleaner and spray all the lines and the inlet down. if your rpms change suddenly when you spray a certain area with the carb cleaner, there is your leak. good luck
johnlude85 is offline   Reply With Quote
Old 05-30-2007, 04:08 PM   #10
Car: 04 STI WRB/GLD
I think that I found the problem
The black inlet hose from the intake box has a hole in it right where it clamps to the turbo. Also, the hose that goes from the turbo to the intercooler (red 90) also has a hole in it!!! I found some oil in the red hose, as well as in the diverter valve hose.
How serious is this?
Old 05-30-2007, 05:04 PM   #11
Car: 04 STI WRB/GLD
need help immediately please!!!
Old 05-30-2007, 05:14 PM   #12
Non-Reformed Meth Addict
Car: '06 WRB
IWSTI Addict since: Feb 2006
Oil in the elbow is normal. It's caused by some blow-by. Unless it's alot of oil then it could be turbo seals. The holes in the elbow and the inlet pipe are def going to be your problem as far as boost goes. Replace the elbow with a stocker and get yourself a new inlet pipe (Perrin, APS, Samco, etc.). Be aware they are a pain to install though.
Old 05-30-2007, 05:15 PM   #13
Car: 04 STI WRB/GLD
Yeah, it was a pain to get it pulled away from the turbo to inspect it! The elbow is the stocker, and which of the aftermarket inlet pipes are better?
Old 05-30-2007, 05:20 PM   #14
Car: 06 WRB GOLD STI
Fav Mod: NRA Sticker
IWSTI Addict since: Mar 2006
APS IMO, I just like the build quality of the APS Inlet, its solid metal as opposed to rubber
Old 05-30-2007, 05:21 PM   #15
Fav Mod: Dyslexia
IWSTI Addict since: Oct 2004
Trader Rating: (13)
Get the APS inlet, its the best. The Perrin one can collapse under boost (mine did), I would stay away from all the silicone inlets.
