Old 04-27-2007, 11:07 AM   #1
If in doubt, flat out
Trader Rating: (23)
Default Catch Can Foibles-Nearly Empty after 6k miles-YET ANOTHER POSSIBLE solution tried...
I installed Perrin Dual Catch Cans and Freddie's dual catch can plumbing 3k miles ago. I used the Perrin supplied foam media in each can. Correct connections and air flow to intake were verified at install and when i examined/disassembled them today. When installed, i pushed the filter media against the top of the can so it would... filter. After 3k miles there is about the equivalent of one drop of oil in each can.
My thoughts:
The supplied foam is very dense, maybe when i pushed the foam against the top of the can, i in effect blocked the flow of air. If so could it have damaged the emission control valves in the system?
Like i said, the supplied media is very dense and takes up nearly all of the can perhaps a smaller, less dense foam should be used. Lawnmower foam air filter?
My emission control valves worked previously as was previously verified by the copious amounts of oil sludge in my intercooler and manifold.
Any help/thoughts/experiences would be greatly appreciated.
Old 04-27-2007, 11:21 AM   #2
Non-Reformed Meth Addict
Car: '06 WRB
Default Re: Catch Can Foibles- Empty after 3k miles
I had/have the exact same issue here. Through much head scratching, installation double checking, and consulting the oracles here it came to pass that the stock lines and the fittings with the Perrin cans are much too small. However you have Freddies stuff (very nice) so my suspicion is that the oil comes into the can and hooks a sharp turn right back out due to there being nothing to force it through the media like a divider between the in and out. I also used the stuff that came with the Perrin can and after a while it started to fall apart into little bits in the bottom . I've tried kitchen sponges but they dry up and turn hard as rocks. I'm on the search for the Element Tuning can which looks to be the final can I'll have to buy I hope.
Old 04-27-2007, 12:10 PM   #3
Car: '06 steel grey, son.
Fav Mod: learning how to drive stock first
do our cars really have that much blowby?
try steelwool
nonissan is offline   Reply With Quote
Old 04-27-2007, 12:26 PM   #4
Indiatr0n in yo IWDPL
Fav Mod: Brum Brum
2007 Postwhore King
Ever had your I/C off Tim (nonissan...not snorky Tim...lol).
Old 04-27-2007, 12:37 PM   #5
i guess not.
on my sr20det, i would get at most a couple drops in my can every change.
Old 04-27-2007, 12:52 PM   #6
Fav Mod: Synapse FMIC
How big are the lines? I was using 5/8" ID lines and they were as short as I could get em... although 9/16" ID would probably be a better fit for the head breathers. The can managed to collect a good amount of oil even when vented to atmosphere.
jays05 is online now   Reply With Quote
Old 04-28-2007, 10:46 AM   #7
Trader Rating: (23)
hmm that element tuning piece looks nice but $$$. I think i'm going to fab up some sort of divider. i've got some ideas in my head. Well i'm off to Lowes for Parts!
Originally Posted by nonissan
try steelwool
eh i considered it but when i look at a package of steel wool, i see all the little metal fibers settled at the bottom of the package and think aobut what that might do in my engine. i might be crazy though...
Old 04-28-2007, 11:53 AM   #8
Originally Posted by snorky
...After 3k miles there is about the equivalent of one drop of oil in each can...My emission control valves worked previously as was previously verified by the copious amounts of oil sludge in my intercooler and manifold....
OK, is there any oil now in your I/C or piping? If not, quit worrying and carry on. OTOH, if there is once again "copious amounts of oil sludge", then swab everything out and try running it with no element in the cans for a while.
Old 04-28-2007, 01:48 PM   #9
Trader Rating: (23)
imo it's too soon to tell. theres probably residual oil from before i installed the cans. i should clean my intercooler out, any suggestions of something to get the oil out without destroying the rubber gaskets on the y pipe?
i bought some materials to make a baffle/divider in the cans and some new foam. i'm going to try to assemble something tomorrow.
Old 04-30-2007, 10:53 AM   #10
Trader Rating: (23)
Ok so i made a divider and put a lawmower air filter in the outlet side. I made the divider half the length of the can. That way if it does actually start to fill up, the sludge will have to fill half the tank before cutting off flow. Anyone think this will work? I guess we'll see in a thousand or so miles.
Old 04-30-2007, 12:21 PM   #11
Car: '06 WRB
Hmmm...looks like a good idea there. Post up the results.
Old 04-30-2007, 12:41 PM   #12
...any suggestions of something to get the oil out without destroying the rubber gaskets on the y pipe?
BrakeKleen - do not use Carb Cleaner.
Old 04-30-2007, 12:51 PM   #13
Car: OBP 06 WRX STI
Trader Rating: (44)
I agree, the fittings on the Perrins are way too small. I re-drilled an re-tapped the cans so I could use larger fittings. I use lawnmower type filters in my cans.
Freddie32001 is offline   Reply With Quote
Old 04-30-2007, 12:53 PM   #14
Car: OBP 06 WRX STI
Trader Rating: (44)
That is a great idea, I'll have to give that a try!!!
Old 07-13-2007, 11:42 AM   #15
Trader Rating: (23)
Default Re: Catch Can Foibles- Empty after 3k miles- A possible solution being tried...
3500 mile Update: 1 Can Empty, 1 can with a teaspoon of sludge. Another possible solution will be posted tomorrow.
Hint: Bigger lines and a heat shield
