Old 01-10-2007, 09:13 AM   #1
Car: 06 STi
Fav Mod: borla XR-1
Default Is premium gas necessary?
I got into an argument at lunch today with a guy who drives a G35 about gas. He says you should use the lowest octane gas you can that doesn't result in pinging, and he puts 87 in his G35. I said that a car with a highly tuned turbocharged engine like mine requies 93, but I didn't have a good explanation for the rationale. And I clearly don't want to experiment with 87 for the sake of an argument. So do we really need premium gas?
blackboost is offline   Reply With Quote
Old 01-10-2007, 09:18 AM   #2
Fav Mod: All of them
Im not sure about the G35, but I know the STi needs premium. 91 is ok if you are stock but 93 would be better. Tell your friend to read his owners manual.
Partysub is offline   Reply With Quote
Old 01-10-2007, 09:18 AM   #3
You can get by with 91 (just ask the guys in CA), but 87 would give you real problems. Why try to skimp on it? Let him argue, just keep feeding your car what it needs.
klaymon is offline   Reply With Quote
Old 01-10-2007, 09:20 AM   #4
A.X.D.
Car: 2004 STi
yes. as your car goes into boost, you are at a very high risk of detonating which will (with enough time and/or boost) kill your engine.
higher octane gasoline is more resistant to detonation.
in an emergency, you could add 91 octane (as our California members could tell you more about) but 87 is too low for our cars.
Old 01-10-2007, 09:21 AM   #5
Car: 2005 WRB STi
Fav Mod: roadhead
Send a message via AIM to overdose Send a message via MSN to overdose Send a message via Yahoo to overdose
he's right, you use the least octane that will not produce knock/ping... and with a turbocharged car like ours, that would be 91 (which really should be 93 to be honest)
overdose is offline   Reply With Quote
Old 01-10-2007, 09:21 AM   #6
A.X.D.
Car: 2004 STi
lots of repeat posts! should've written mine faster.
Old 01-10-2007, 09:21 AM   #7
DOMINATOR
Fav Mod: Strut Clunk
When you spend 30k+ on a car why not spend the extra $1.00 a fill up to put the correct gas in? I mean you're talking a max of about $50 extra a year to go from 87-91. (I'm referring to the G35 guy, cuz there is no way 87 is the recommended gas for that car)
Old 01-10-2007, 09:24 AM   #8
Car: 06 STi
Fav Mod: borla XR-1
I would never put anything less than premium in my car, I'm just arguing with a fellow scientist and I couldn't come up with a satisfactory mechanistic reason. So higher octane= more detonation resistance. Not to be too annoying, but does anyone know why?
Old 01-10-2007, 09:26 AM   #9
http://en.wikipedia.org/wiki/Octane_rating
Old 01-10-2007, 09:27 AM   #10
Car: 2005 WRB STi
Fav Mod: roadhead
because higher octane fuel doesn't combust as easily, therefore lower octane fuels are more succeptible to detonation/pre-iginition from heat
Old 01-10-2007, 09:38 AM   #11
Car: 07 STI Limited
Just read him this:
Originally Posted by http://auto.howstuffworks.com/question90.htm
The octane rating of gasoline tells you how much the fuel can be compressed before it spontaneously ignites. When gas ignites by compression rather than because of the spark from the spark plug, it causes knocking in the engine. Knocking can damage an engine, so it is not something you want to have happening. Lower-octane gas (like "regular" 87-octane gasoline) can handle the least amount of compression before igniting.
The compression ratio of your engine determines the octane rating of the gas you must use in the car. One way to increase the horsepower of an engine of a given displacement is to increase its compression ratio. So a "high-performance engine" has a higher compression ratio and requires higher-octane fuel. The advantage of a high compression ratio is that it gives your engine a higher horsepower rating for a given engine weight -- that is what makes the engine "high performance." The disadvantage is that the gasoline for your engine costs more.
Why not pay a little more for gas that is better (less knock) for your engine?
We also have 91 craptane in Seattle, just like Cali does.
Real Deal is offline   Reply With Quote
Old 01-10-2007, 09:38 AM   #12
A.X.D.
Car: 2004 STi
also, IIRC lower octane fuels don't burn as pure or clean as higher octane fuels, leaving carbon deposits on the pistons - this in turn (the carbon deposits) keep retaining heat which will glow red hot (like coal in a blacksmith furnace) which will get hot enough to explode the air/fuel before the spark plug can (detonation).
the higher the octane, the "cleaner" it burns, in turn keeping your pistons "muck" free.
Old 01-10-2007, 09:43 AM   #13
NIИja
this is what ive understood in regards to octane.
the higher the octane, the cleaner the fuel burns.
Old 01-10-2007, 09:50 AM   #14
Reasonable
Fav Mod: correct grammar
This should be added to the newbie thread of interest: Why do I have to use Premium Fuel? Good info in this thread.
Old 01-10-2007, 10:03 AM   #15
A.X.D.
Car: 2004 STi
Newbie Threads of Interest
done. thanks for the suggestion.
