Old 11-09-2006, 07:34 PM   #31
GT R US
IWSTI Addict since: Dec 2003
dude, youre going to look like a freakin' genius if that all works out. i really admire your fabrication skills. the turbo location is killer. it's reminiscent of that crazy russian sti on that dyno video.
Old 11-09-2006, 07:45 PM   #32
IWSTI Addict since: Jun 2006
Lookin good! How long has this taken you?
STi_1212 is offline   Reply With Quote
Old 11-09-2006, 08:10 PM   #33
Car: white 04 sti
Fav Mod: s374
IWSTI Addict since: Dec 2005
on and off like 4 weeks
fobiawrx is offline   Reply With Quote
Old 11-09-2006, 08:47 PM   #34
Moderator
Car: 05 Ram 3500 CTD
Fav Mod: Majin
IWSTI Addict since: Apr 2006
that TB looks like it is made of some pretty thin material, i dont think it will hold boost and if it does I would imagine you will get pressure drop and cracking due to expansion/contraction from on/off boost. It is very difficult to get 2" sch 80 (~5/16" wall thickness) seamless pipe to hold more than 50 psi without finding leaks in welds, I think 20psi on that would be impossible. I dont want to rain on your parade, I just would hate to see you waste your time. Welds are your enemy on a pressurized cavity, hence most high pressure intakes being cast, thick and heavy.
Old 11-09-2006, 08:49 PM   #35
I'm also interested to know did you make it free hand or designed it (drafting by hand, auto-cad, or some type of 3-d cad software ie. Solidworks / Inventor)?
Sorry for all the questions
Old 11-09-2006, 08:55 PM   #36
Car: white 04 sti
Fav Mod: s374
been serching around and looking at all the cars that have been making alot of power and this is what i cam up with. more free hand then maped out but with close mesurments. now from what i read a bigger plentum means more top end hp and longer runners with a smaller plenum means more tq. hear is my happy medum. 2.25 16 gage runners and 3/16 sheet metal. should hold up fine.
Old 11-10-2006, 12:11 PM   #37
Car: PSM '04 STi
Fav Mod: 6pt harness
IWSTI Addict since: Apr 2004
nice work, want a job?
When I'm making the Indycar oil coolers I have to pressure test them at 50psi. I make the end tanks from 16ga 5052 aluminum. The tanks are hand formed and have compound radii, which makes them very strong and light. So definitely make some plugs and pressure test your bits by filling with shop air to at least what your boost pressure will be. Then either submerge in water looking for bubbles, or use a soap/water solution sprayed to the outside and look for bubbles. This should be done as the last step before paint or polish. If it holds, your done. If not, fix the leaks. I have had success with sheet metal intakes by bracing the plenum for expansion/contraction. I use 1/2" or 3/4" round stock. Drill a hole through the plenum on both sides, insert rod, weld in place. This keeps the movement to a minimum so the welds don't crack.
Good luck.
nero9 is offline   Reply With Quote
Old 11-10-2006, 12:27 PM   #38
Car: white 04 sti
Fav Mod: s374
Good luck.
got any pics of the plentum bracing
Old 11-10-2006, 12:53 PM   #39
STI Master
Car: 04 JVP STi
Fav Mod: Blitz NUR Spec R
Looks nice. Hope you don't melt your front tire with that 6" down pipe
Old 11-10-2006, 01:14 PM   #40
IWSTI Addict since: Oct 2006
dang I can't wait to see the video when all of this comes together and you open up the cutout!!! dang that turbo is gonna sound sick!!
bullittman68 is offline   Reply With Quote
Old 11-10-2006, 03:28 PM   #41
Fav Mod: jailbreak
IWSTI Addict since: Aug 2003
you are awesome! such an original idea!! great work, keep it up! when it's done i think pretty much any tuner shop in the world would hire you
Old 11-10-2006, 09:50 PM   #42
Car: white 04 sti
Fav Mod: s374
wow thanks for all the support! nice to know you all like what i am doing
Old 11-11-2006, 11:26 AM   #43
How long approximately till you get it up and running?
Old 11-11-2006, 11:49 AM   #44
Fav Mod: Perrin 30r Kit
IWSTI Addict since: Apr 2005
pretty badass. cant wait to see it all together and running.
Old 11-11-2006, 02:24 PM   #45
Car: white 04 sti
Fav Mod: s374
hopefully spring. once i get the parts built and finished then i will buy the parts for it. kind of depends on how much money i make over the winter. and tax time of corce.
