Old 11-08-2006, 07:12 AM   #16
Car: white 04 sti
Fav Mod: s374
Originally Posted by blindfold
Wonder what gauge APS used on their header.
I have been doing some thinking about headers and manifold issue. Last time I checked Inconel is the best material for headers/manifolds. Now we need a group buy on some exotic inconel equal length headers. The material is so awesome that no heatwrapping or thermal coating is needed. The only downside is that the raw material is quite expensive.
A general desciprtion of inconel -->http://en.wikipedia.org/wiki/Inconel
isn't that that super thick heavy stuff? you see Honda guys using it all the time. if its what i think it is my manifold would be 100lb!
fobiawrx is offline   Reply With Quote
Old 11-08-2006, 07:22 AM   #17
Moderator
Car: 05 Ram 3500 CTD
Fav Mod: Majin
Inco comes in different guages just like any other metal. It is more dense than SS, but not so much that it would be 100lbs. The only thing I would worry about on that header is the stovepiped bends. That will be the weak point imho. Very nice work though. IDK what you do for a living, but you could make pretty damn good money as a union fitter welder esp. if you got good enough at tig to do nuke work...
Old 11-08-2006, 12:00 PM   #18
Car: white 04 sti
Fav Mod: s374
lol! i work for myself doing construction. i was a trimmer full time for 5 years and now am a tile setter/ remodeler. this is the first time i have ever worked with metal.
Old 11-08-2006, 07:25 PM   #19
Car: white 04 sti
Fav Mod: s374
got the cut out section done today! looks pritty cool to me. should work out well i think. sits two inches below bottom of the bunper. so even with the lip i will put on later. what do yah think?
Old 11-08-2006, 08:19 PM   #20
Car: 2005 White/Gold STi
Fav Mod: TD06-20G/Tein Flex coilovers
That is one crazy setup, man.
I'm interested to see the final results.
pt518sti is offline   Reply With Quote
Old 11-08-2006, 08:21 PM   #21
STI Master
Car: E46 M3
Fav Mod: ZCP Wheels
Trader Rating: (77)
Craziest setup Ive seen to this day....great stuff!
Old 11-09-2006, 06:52 AM   #22
Car: 2005 STi
Fav Mod: Stage dos.
wow cant wait to hear that one!!
609Audio is offline   Reply With Quote
Old 11-09-2006, 08:57 AM   #23
DOMINATOR
Fav Mod: Strut Clunk
That exhaust/downpipe thingy confuses me.
Old 11-09-2006, 09:16 AM   #24
Moderator
Fav Mod: Majin
Make sure you dont do any welding with the piping bolted to the turbo... you can and likely will get bearing arc. You really shouldnt weld with it attached un-insulated from the motor either. If you were worried about it pulling just get some flatbar and mimic the exhaust port bolt holes and bolt it to that for welding. You also may consider doing an argon purge on the piping for the weld, otherwise youll get porrosity from the oxygen on the inside.
Old 11-09-2006, 12:10 PM   #25
Car: white 04 sti
Fav Mod: s374
thanks for the info! i havant been welding with the turbo on but have been alittle on the motor. going to be doing a full build on that though.
Old 11-09-2006, 03:43 PM   #26
Car: 04 WRB STI
Fav Mod: vf36
I've been wanting to get a tig welder. Which one you using? Miller or Lincoln. They're pricey though $700 to in the thousands. I would just want the capablity for 421 stainless steel and aluminum. I guess I should take a class at my local community college. I would love to fabricate my own twinscroll rotated setup and ic piping for reversed manifold.
calisti is offline   Reply With Quote
Old 11-09-2006, 04:40 PM   #27
Moderator
Fav Mod: Majin
I am partial to the lincoln squarewaves, especially if you are doing alum. Otherwise any Miller xmt will do the trick. Plan on spending thousands for a nice lincoln squarewave. Make sure you get a machine that has a foot control if you want to do aluminum, it seems to require a lot of heat changes to get a good weld.
Old 11-09-2006, 05:54 PM   #28
Car: white 04 sti
Fav Mod: s374
Default and now a intake manafold! pics!
check out what i got tacked up! not done yet cuz i have to round out ware the runners meet the plentum and i havent decided how i want the tb done. open to suggestions....... well really i havent decided if i want to keep the stock tb or go bigger. its set up for stock in the pics.
as far as welders i have a miller mig right now and will be perchasing a miller econotig wich is $1400 in dec. thats why every thing is just tacked for now.
Old 11-09-2006, 06:19 PM   #29
520
STi > EVO... Wait what???
Car: 03 EVO
Fav Mod: stock :(
Send a message via AIM to 520
sick, that exhaust is gonna be LOUD
Old 11-09-2006, 06:24 PM   #30
Car: 05 STI
Fav Mod: Twinscroll GT37R
Send a message via AIM to ITSASTI
very cool that your doing all the work.... i just hope it runs!!
ITSASTI is offline   Reply With Quote
