| Professional STI Driver | I am trying to figure out what is the easiest way for me to get my turbo upgrade done (decided on the fp green) ... tuner will be here one week after I can get the stuff installed, so from what I heard, the car will not run with new injectors unless tuned - correct? So I'll probably have to install everything, but injectors and then get the injectors installed before the tune. maybe get a base map? Any ideas? How hard / long is it to swap the injectors on the STi? Thanks This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #3 |
| Spec C Club
Car: Blue 05 STI Fav Mod: 4th gear wheelspin Location: Upstate NY Posts: 1,888
IWSTI Addict since: Nov 2004 Trader Rating: (0) | The injector install is pretty easy, I did it in my driveway with just basic hand tools. You might as well swap plugs (if you had been planning to go to colder plugs) and do a compression test at the same time. |
| | #4 | |
| Moderator & ECU Tech
Car: 05 CGM STI Fav Mod: mo boostaz Location: Fredneck, MD Posts: 3,716
IWSTI Addict since: Jun 2004 Trader Rating: (6) | Quote:
You definitely don't want to run injectors untuned. No way. Don't even try. t | |
| | #5 | |
| Spec C Club
IWSTI Addict since: Nov 2004 Trader Rating: (0) | Quote:
| | #6 |
| Professional STI Driver | I plan on doing the install one day before the tune and car won't run until Scott Siegel gets to it ... I was thinking about doing everything, but injectors, but I don't like the idea of a base map. Gotta do it right the first time. Thanks for all replies. This ad is not endorsed by this member. Please register or login to hide this ad. |
