Old 05-09-2006, 09:30 AM   #76
Car: 02' WRX Sedan PSM
Fav Mod: 2.5L
Gooks great! BTW what paint did you use to paint your FMIC?
Thanks.
coolcougar is offline   Reply With Quote
Old 05-09-2006, 09:43 AM   #77
Thanks. I need to do an outdoor day pic.
I didn't paint it. You can get it in silver or black.
Old 10-31-2006, 02:45 AM   #78
This is a great thread, it really helped me with my DR525 install...
Anyway, thought I'd share my experiences and pictures...
My car is an MY06 JDM STI Spec C Type RA, and I did find a few minor issues:
- M/T cooler lines interfere with the new coolant reservoir bracket. Had to install a small spacer to clear the cooler lines, still a little bit of movement in the reservoir tank
- M/T cooler lines at the bottom of the radiator block the hot side piping. Had to bend them apart to allow the hot side piping to clear
- Cold side pipe is hard up against the turbo coolant tank
- Hole in front bracket on hot side pipe doesn't line up to anything
- Don't tighten the brake booster adapter too hard - I snapped mine - luckily I got it out with an EZ out and they are readily available fittings from any hydraulic/pneumatic shop
- If you have a larger thicker aftermarket radiator, it is real tight behind the radiator!!
Here are some pictures:
Engine Bay - pipes were originally wrinkle red, now are HPC coated...
Intake and Oil Cooler - fits nicely with the FMIC piping...the Oil Cooler is the factory Spec C cooler, it was repositioned when my previous Power Enterprise V-Mount kit was installed...
New Koyo Radiator
Radiator comparison - Koyo radiator is almost twice as thick...
FMIC installed with bumper and new grill...
This picture allows you see the grill shape and I/C behind it better...
Oil Cooler duct (if you look closely, you can see the oil cooler behind the duct mesh...
Side view of the bumper - you can see there is a gap between the bumper lip and the undertray - I'm getting a panel made up to close off this gap...
sti8u is offline   Reply With Quote
Old 01-05-2008, 10:53 AM   #79
Car: 2008 sti Aspen White
Fav Mod: Tial 38mm EWG Suspension
Send a message via AIM to Trackscoob19
Default Re: Anyone who has installed APS DR725 or DR525 FMIC
This will help alot with my install thanks guys
Trackscoob19 is offline   Reply With Quote
Old 04-02-2008, 08:59 AM   #80
Car: WRB 2005 STI 404whp!
Fav Mod: COBB AccessPort
Send a message via AIM to dexterous
I just got my DR725 installed. This thread was very helpful, thanks guys. I have not cut my bumper yet as I am really intimidated by the thought. Anybody out there have any advice? I would really like to know what I should use to cut it with. Thanks.
dexterous is offline   Reply With Quote
Old 04-05-2008, 07:49 PM   #81
Finished with the bumper and I think it looks really good but I unfortunately have run into a few fitments issues.
Bumper:
The IC piping impacts into the timing belt cover:
I started a thread on the fitment issues: APS DR725 FMIC Fitment Issues (With Picts)
