| Junior STI Driver | If I get an aftermarket wastegate installed on my VF-39, will it eliminate boost creep? I am running stage 2 with a catless downpipe. I have seen my boost gauge hit 20-21psi in some gears. Id rather not port my wastegate, since I wouldnt trust anyone here in Houston to do it. Could I go with an external wastegate? And how would that affect my engine or tuning with cobb? This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #2 |
| Spec C Club Car: 08 CBR1000RR Fav Mod: None Location: Kansas Posts: 2,452
IWSTI Addict since: Jun 2004 Trader Rating: (6) | Here ya go: http://www.pghsubarus.com/tech/porting/porting.aspx You should change your base and real time maps to the LWG maps. This will help compensate for the boost creep, but it won't fix it. You could port it yourself. An external gate would be very costly. You would have to weld the wastegate flapper shut on the internal gate. Then change your uppipe to incorporate the wastegate. I thought your were looking to upgrade to a larger turbo in the future? If so, just run the LWG maps until you can get your new turbo, unless of course it is going to be forever till you upgrade. Last edited by ninjaboy76; 04-18-2006 at 05:08 PM. |
| | #5 |
| The Hoff Fan Club, member #001 Car: 05 WRB/Gold Fav Mod: Hood Scoop Homer Location: Where ever The Hoff is! Posts: 10,365
IWSTI Addict since: Jul 2004 Trader Rating: (4) | boost creep is bad for the engine because it can cause you to run lean. yes, an ewg would get rid of boost creep but most people dont put one on the stocker. |
| | #6 | |
| S204 Racer Car: 05|WRB|STi Fav Mod: Cobb Stage 2 Location: H-Town, NJ Posts: 3,796
IWSTI Addict since: Aug 2005 Trader Rating: (3) | Quote:
| | #7 | |
| Professional STI Racer Car: 05 PSM STi w/ custom Fav Mod: TiaL 38mm vented free as a bird. Location: Maine Posts: 620
IWSTI Addict since: Mar 2005 Trader Rating: (1) | Quote:
| | #8 |
| Junior STI Driver | I just read that entire article. But Im still unclear as to what exactly is BAD about it. Sure, boost keeps crawling up, but does that affect the engine? or turbo longevity? |
| | #9 | |
| Lurker Car: 05 Subaru STi Fav Mod: GT35R Hydra Location: Puerto Rico Posts: 2
IWSTI Addict since: Mar 2006 Trader Rating: (0) | Quote:
YES!! | |
| | #10 | |
IWSTI Addict since: Jun 2004 Trader Rating: (6) | Quote:
| Thread Tools | |
