Old 05-24-2007, 10:59 PM   #46
Car: 05 WRB/Gold
Fav Mod: Hood Scoop Homer
Default Re: Read this before you create a new thread about BOVs (Blow-off valves)
50/50 isn't as bad as 100 but still is not good
Old 05-25-2007, 03:22 AM   #47
I was about to get a new Hks bov for 2004 sti, but after going through this thread finally decide to spend in some performance parts.
Thanks Guys...
Lovebhai007 is offline   Reply With Quote
Old 05-25-2007, 05:30 AM   #48
issuer of points and bans
Car: 2004 STi
Originally Posted by howboutthemapplz
everyone is talking about one extreme or the other, as far as recirc or atmosphere. what does everyone think about a 50/50? now that we understand that the full atmosphere is no good... has anyone had any experience with a 50/50??? any opinions on the 50/50??
i have a 50/50 for over a year now - it's better than a full venting BOV, but it's still not as good as a full recirculating (although my car was tuned for my BOV/BPV and other mods).
Old 07-24-2007, 04:52 PM   #49
Car: 07 STi
Fav Mod: ipod mount
What made you decide to go with a 50/50 over a full recircluating valve? On that note, I know in the rally vids I've watched you can hear the BOV... is that a 50/50 as well, or is it full recirc and its just very noisy? Or something else?
variable is offline   Reply With Quote
Old 07-25-2007, 06:07 AM   #50
Car: 2004 STi
i went with a 50/50 because i wanted the BOV sound and some backfire, but not a rich stumble that couldn't be mostly corrected with a protune.
i am uncertain of the rally cars.
Old 07-25-2007, 06:11 AM   #51
Moderator
Car: 05 Ram 3500 CTD
Fav Mod: Majin
Those rally cars are a completely different animal. Other than the general shape of the body and displacement of the motor, there are no real similarities.
Old 07-25-2007, 06:12 AM   #52
Moderator
Fav Mod: Majin
and what you were hearing was probably anti-lag.
Old 09-04-2007, 05:35 PM   #53
Car: 2007 Subaru Impreza
Fav Mod: Cobb AP
Great thread. I also put my old Blitz BOV from my old rex onto my STi, just for giggles and time killing. Anyway, although the car makes lots of cool noises, like compressor surge flutter, hissing noise with no boost, pssshh between WOT shifts, and bang-bang from the exhaust, but I can tell my car is telling me to take this POS off. The car drove like crap, made me feel like I was driving a Dodge Shadow from the 80s, so I took it off right after and went for a drive with the stock BPV, much nicer, everything went back to normal. It was nice to kill an hour though.
2MANYCARS is offline   Reply With Quote
Old 01-22-2008, 09:31 AM   #54
No Rice
Car: 06 OBP STi
Fav Mod: Brake dust
Ok so from this thread we can deduce that there are a lot BOV cons. I still dont see any pro's... Do they exist? The noise doesnt count.
Seppo is offline   Reply With Quote
Old 01-22-2008, 10:53 AM   #55
Car: 2004 STi
depending on your aftermarket BOV/BPV you may need one after running higher than approximately 22 PSI. someone that knows the exact limit on the OE BPV could chime in with less ambiguous info.
Old 01-22-2008, 11:22 AM   #56
Car: 06 Subaru STi
Fav Mod: Deadbolt 20G
When my tuner dynoed my 06 STi with a 20G, he went to around 22-23 lbs. of boost, and the stock bpv would not stay closed, so I had to get a bov.
Okeyd57 is offline   Reply With Quote
Old 01-22-2008, 12:33 PM   #57
No Rice
Car: 06 OBP STi
Fav Mod: Brake dust
^ Can't you just get BPV that will hold better than stock?
Old 01-22-2008, 01:43 PM   #58
Car: 2004 STi
you can crush the OE BPV so that the spring's set is closer to the valve itself, in turn increasing the amount of boost the valve will stay shut against. you only have one chance to do it right though, so if your tuner is familiar with this "mod" and has done it already, i would probably let your tuner crush it.
i was more comfortable with just getting a BPV/BOV instead that has the ability to recirculate 100%.
Old 01-26-2008, 06:39 PM   #59
Car: WRB 06 STI
I have a few further questions. Is anyone running a blow through MAF after the BOV? If so, theoretically it wouldn't matter right?
Also, does a BPV reduce lag between shifts with larger turbo's?
How does the spring rate (15 lb, 7 lb ect) rating in a BPV or BOV compare to your boost levels?
EESTI is offline   Reply With Quote
Old 01-26-2008, 07:07 PM   #60
Car: Silver Euro 07 STi
The only reason I know for using BOV is that if you are using Hydra of other EM and running w/o the MAF. If you have a ball bearing turbo, why not try to run it w/o BOV or BVP like Crawford does? modaddicts car runs very nice w/o the BVP/BOV
If you are using the stock turbo, just stick with the stock BPV
