Old 03-12-2006, 02:28 PM   #1
Car: 05 Subaru Sti
Fav Mod: They all work as one (All)
IWSTI Addict since: Sep 2005
Question Big td05 16g turbo?
Want a little better turbo than what comes stock on the STi and have a chance to get a reasonable price on a big TD05 16g that has been fully ported. What do you guys think? What are your thoughts on this turbo??? Thanks in advance!!!
sti 5501 is offline   Reply With Quote
Old 03-12-2006, 02:44 PM   #2
Car: '05 STi
Fav Mod: WOT
IWSTI Addict since: Mar 2006
Send a message via AIM to dubrexer
Default turbo for '05 sti
i would not do anything smaller then an fp green personally.
that car can make a lot of clean power pretty efficiently with a damn good tune on the stock block. which is definitely a lot of fun for a daily driver - i'm talking 360 to 380 pump not to mention what more you can squeeze from race gas - it's just a question of how long you can do that until you're built
dubrexer is offline   Reply With Quote
Old 03-12-2006, 02:51 PM   #3
Car: 05 STI
Fav Mod: Invidia N1-R
IWSTI Addict since: Sep 2004
I think the 16g is too small
KiNgMaRtY is offline   Reply With Quote
Old 03-12-2006, 03:18 PM   #4
Car: 05|WRB|STi
Fav Mod: Cobb Stage 2
IWSTI Addict since: Aug 2005
Send a message via AIM to SoaReS
20 g
SoaReS is offline   Reply With Quote
Old 03-12-2006, 03:24 PM   #5
Car: 05 STI
yeah only 4 more g's to go
Old 05-22-2006, 11:59 PM   #6
IWSTI Addict since: Apr 2006
Exclamation
While I don't plan to do it anytime soon. I do have the same question. What size of turbo is good for upgrading from the existing STI w/o mod. on intake exhaust or fuel pump, etc.
Is putting in a bigger turbo possible to gain some power?
EL
Old 05-23-2006, 12:04 AM   #7
Car: Silver 05 WRX STi
IWSTI Addict since: Dec 2004
Send a message via Yahoo to import111
The only turbo that you can safely put on the STi with out any supporting mods would be the VF34. Anything bigger and you are gonna need more fuel to be safe.
And the 16g is pretty small for an upgraded turbo on an STi. I would at least go td06 18g, or td05 20g.
import111 is offline   Reply With Quote
Old 05-23-2006, 12:25 AM   #8
Exclamation
So, say I have the AP Stage 1.
w/o mod. on AP Stage 2, or intercooler, etc. Ones can safely run the following?
VF34
td06 18g
td05 20g
What would be the gain!?
Old 05-23-2006, 07:15 AM   #9
Car: 05 WRB/Gold
Fav Mod: Hood Scoop Homer
IWSTI Addict since: Jul 2004
VF34
td06 18g
td05 20g
you can not run any aftermarket turbo on just a stg 2. you need to get a protune.
the smallest turbo anyone should be considering is a 20g. Considering that people with meth can make 320-330whp on the stock turbo there is no point "upgrading" to a turbo that will net you 10 or 20whp more. Maybe the 18g will give you more top end, but i dont see the point.
when you upgrade your turbo you NEED new injectors and a custom tune. no if's and's or but's.
you can put a turbo on without any other mods, but it makes no sense. think of it this way. if somone's heart is damaged and the veins around it are all clogged, you can put a new heart in but it won't be able to work at it's full potential unless you clear out the veins around it. same thing with our car and not upgrading intake, exhaust, fuel, ecu, etc.
Old 05-23-2006, 07:20 AM   #10
Fav Mod: FYI, I'm a dude
IWSTI Addict since: Mar 2005
^^ +1. the stock unmodified injectors are pretty much maxed out using the vf39. any larger turbo is going to require new injectors or modified stockers. also get a upgraded fuel pump. you can stick with the stock tmic up to a 20g w/o any issues. you'll just be leaving some hp on the table. the smallest turbo i would upgrade to is a 20g.
Old 05-24-2006, 03:19 PM   #11
Default More questions
So, would the Cobb AP do me any good with a Protune? I already bought it, and I will change my to stage 1. Then later on, I will get the min. requirement for movnng it to stage 2. A slightly bigger turbo which can bolt on.
I am not looking for a monster speed machine. Just want to get the potential out from it. so, no new brake, clutch, fuel pump, injector, etc.
The Stage 2 AP, is suppose to mean new turbo back exchaust, would that not give me enough room to put in a 20G or maybe a VF everyone who talk about?
EL
Old 05-24-2006, 03:34 PM   #12
Wheel33tist Whore
EL
the stock STi injectors are seeing upwards of 110% on the stock turbo.
any larger turbo will need larger injectors. if you want more power than the stock turbo can provide you have to get new injectors (or modify the stock ones), and a fuel pump. Hell an upgraded fuel pump is reccomended by some tuners on the stock turbo.
to run a 16g, Super16g you will need at least 650cc injectors (our stockers are about 100ccs short). if you don't want crazy power but are willing to pay the same amount it would cost to get crazy power the TD06H-Super16g from deadbolt will flow nearly as much as an 18g but provide better spool.
with the TD06H-Super16g work with stock injectors, and fuel pump? NO.
will it work with a off the shelf AP map? NO
you seem scared to upgrade your injectors, why is that?
Old 05-24-2006, 03:57 PM   #13
Thanks for the info. The info. here has been great. I suppose I should hold off right around AP Stage 2, then decide on what to get into later..!
EL
Old 05-24-2006, 04:09 PM   #14
Wheel33tist Whore
yup Stage 2 is a good place to be.
and if you crave more power above that, get a fuel pump and a protune.
then go from there.
Old 05-24-2006, 04:30 PM   #15
jph
Car: the wagon
IWSTI Addict since: Apr 2004
i have been thinking that a td06h-18g might be a nice mild turbo upgrade from the vf39.
same (if not better) spool, and more topend.
but there are not too many people who have done that so, there isn't much information on td06h-18g equipped sti's available.
whatever you do, do not get the td05, that's too small for a 2.5L
J.
