| Professional STI Racer Car: 05 STi Fav Mod: HEET, Scott Siegel Tuning, Lots of BOOOOST Location: Tampa Posts: 810
IWSTI Addict since: Nov 2004 Trader Rating: (1) | anyone running a perrin fmic with an oil cooler? ive been thinking of picking up an oil cooler but want to make sure it fits with the fmic. anyone have any insite on this? thanks This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #2 |
| Junior STI Driver Car: 04 STI WRB 402whp/38 Fav Mod: Tilton Carbon Carbon Clutch Location: North Carolina Posts: 117
IWSTI Addict since: Jan 2005 Trader Rating: (0) | I have the TXS FMIC and I have some interference problems. I ended up having to insulate one from the other but no real big deal. With the Perrin though you might have a problem with the new bumper beam. Hope this helps. |
| | #3 | |
IWSTI Addict since: Nov 2004 Trader Rating: (1) | Quote:
| | #11 | |
i wanted to see what you had to insulate the oil cooler | |
| | #12 |
IWSTI Addict since: Jan 2005 Trader Rating: (0) | The same adhesive heat tape that I wrapped the charge pipe in is what I put on the upper right corner of the IC to keep the IC and OC seperated |
| | #13 |
| The Next Petter Solberg Car: 2004 Aspen White STi Fav Mod: TiAL 44mm w/g Location: San Francisco, CA Posts: 994
IWSTI Addict since: Sep 2003 Trader Rating: (0) | I've been running a Perrin FMIC with a Process West FMOC for a few months now...ZERO fitment problems with the Perrin intercooler. Just make sure you wrap the oil lines at the portion closest to the header(as a precaution) AND also wrap where they come through the metal bumper support to avoid any future chafing of the lines due to vibration. here are some pics of mine... ![]() ![]() |
| | #15 | |
IWSTI Addict since: Sep 2003 Trader Rating: (0) | Quote:
You can get this stuff at most auto parts stores, I bought from NAPA auto parts. For the portion of the hose that rubs against the metal bumper support, I just used your standard flexible plastic conduit wrap(same stuff that the factory uses over wiring harnesses in the engine bay). This stuff you can get at any Radio Shack. It's ALWAYS a good idea to take preventative measures especially when you're dealing with oil lines. This ad is not endorsed by this member. Please register or login to hide this ad. | |
