Old 02-14-2006, 10:53 AM   #1
Fav Mod: Not working in the Summers!
Default Total Price: Turbo Upgrade?
From your own experience what is the total price "out the door" for a larger turbo + supporting mods?
turbo, fmic or tmic, injectors, hoses, tuning, labor, etc...
thanks
RUGBY is offline   Reply With Quote
Old 02-14-2006, 11:12 AM   #2
Car: 2005 & 2008 STI
Fav Mod: UR 35R and Hydra tune by Scott Siegel :)
Send a message via AIM to JDM-STI Send a message via MSN to JDM-STI
Mine was around $3500 without tuning and labor. I do my own labor and the tuning is yet to come. If you go all out, probably in the $4000-5000 range.
JDM-STI is offline   Reply With Quote
Old 02-14-2006, 11:25 AM   #3
Car: Was: 05 Aspen White
Too many variables. You could get a nice 20G package that utilizes the stock TMIC with supporting mods and a tune for right around $2,000 or... you could spend $2,000 on a turbo alone (ie DB SZ55.) What are your goals for this upgrade?
RSVCHAD is offline   Reply With Quote
Old 02-14-2006, 11:53 AM   #4
Goal:
BA car from 0-150
Old 02-14-2006, 11:57 AM   #5
So you will just be using this car strictly to do sprints from a dead stop to 150 mph all the time? You should budget for a rotated GT35R kit with the largest A/R you can get your hands on.
Old 02-14-2006, 12:05 PM   #6
I would definitely not say all the time. From 0-60 the car is very impressive. However, I would like to improve the roll acceleration w/o hurting the 0 to 60 times.
I really like the lifetime rebuilds that Deadbolt offers.
Old 02-14-2006, 12:32 PM   #7
A good top-end rush w/out losing much bottom end, huh? I would personally due a 3" inlet FP Green or a rotated GT30R kit with all the supporting mods. Both of these options offer up pretty quick spool and have a very nice top-end. Add water/alcohol injection for good measure. Either of these set-ups with water/alcy injection should give you enough power to accelerate "briskly" to 150mph.
Old 02-14-2006, 03:29 PM   #8
I totally agree.
Old 02-14-2006, 03:34 PM   #9
Car: 05 STi CGM
Fav Mod: Tuning...
Depends on how far you get into it. My GT30R parts by themselves were around $5k.
Nixlimited is offline   Reply With Quote
Old 02-14-2006, 03:49 PM   #10
SZ55 is a great turbo as well. A lot of top-end with a small penalty in spool compared to the Green or GT30.
Cost for a standard SZ55 set-up without tuning or install should run about $4,500.
Old 02-14-2006, 03:58 PM   #11
Perrin GT30R rotated mount kit $2700
Crawford / RPS Clutch $600
APS DR725 FMIC $1500
PE 850cc Injectors $750
Walbro Fuel Pump $100
Install $1,200
Tuning $450
That is what I purchased for my car last month....that's $7,300
But before I could get it installed I blew my motor....so last week I had to add to that:
Cobb Tuning Stage 2 Built Block with options: $4300
So that takes me up to $11,600
But that is doing it without cutting any corners....if you want instant gratification you could go with a Green or SZ49 and use the stock topmount until you save up more....with a setup like that you could get away with $3500 installed.
2LTL2L8 is offline   Reply With Quote
Old 02-14-2006, 04:42 PM   #12
Fav Mod: Stealth mode
Install $1,200
Tuning $450
Off-hand, I think the APS intercooler is overkill for the GT30R (but you won't be sorry if you do upgrade from there), so you could knock $400 or so off that cost for a Perrin or TXS FMIC. I've also seen 820cc injectors for under $500. And of course DIY knocks a whopping $1200 off the install cost, so in total if you threw these compromises in, that would knock it down to about $5500 for a pretty kickass setup.
Of course that leaves out any exhaust or intake upgrades, but you already have those.
Snax is offline   Reply With Quote
Old 02-14-2006, 06:46 PM   #13
Car: 05 STI
your wating your time if you run a GT30R kit and a TMIC.....
Old 02-14-2006, 06:48 PM   #14
Car: 05 STI
I will tell you unless you are purely after numbers that the 20G upgrade is more than enough to make you smile. I ran that setup before my current and it was a great setup. The difference to go the next step as I did, the guys are telling you correctly. It will cost you roughly $7,000+ to do it right...
thanks
Old 02-15-2006, 03:47 AM   #15
Heres my list:
SZ55 - $1,995
Cobb AccessPORT - $640
Cobb StreetTUNER - $400
Perrin FMIC - $1,100
Perrin Turbo Inlet - $200
Perrin BigMAF Intake - $200
PE 850's - $650
Perrin EBCS - $75
Walbro FP - $80
TBE - $1000
Tuning so far - $550
Install - FREE
TOTAL - $6,890 <--- Holy F!!! Thats the first time I added it up. Shouldn't have done that. Im an idiot.
1FastSTi is offline   Reply With Quote
