Old 01-23-2006, 08:07 PM   #1
IWSTI Addict since: Jan 2006
Send a message via AIM to aznkrunk
Default safe daily driver with 3k spent
okay well i got an 04 sti and i am wondering what i should do to spend around 3k safely into engine having it as a safe daily driver car.
this is what i thought up
Xs Engineering Turbo Back exhaust about 1.2k
Access port with street tuner around 1.1k
intake what brand would be best
up pipe thinking xs engineering not sure
blitz blow off valve
gimme ur thoughts and opinions and with me doing that much work would i need anything else for this to be a safe daily driver
aznkrunk is offline   Reply With Quote
Old 01-23-2006, 08:10 PM   #2
STI Master
Car: E46 M3
Fav Mod: ZCP Wheels
IWSTI Addict since: Aug 2005
Trader Rating: (77)
Turboback good idea.
Street tuner, ehh..you know what your doing? Just get the Ap for now, then a protune
Intake, only good for a few hp, but it sounds cool I guess.
No need for an upipe, stock one is catless!
BOV? no point on stock turbo, you want the sound I guess get the intake.
I would go with the turboback, and AP for now. Put on some springs such as pinks or tanabe's and some sways and Id consider that a nice daily driver.
If you just want power just the intake, exhaust, and AP.
Old 01-23-2006, 08:16 PM   #3
I Has a Turbo Timer
Fav Mod: Every single one!
IWSTI Addict since: Jun 2005
Trader Rating: (30)
Ditto, you don't need an up-pipe or the BOV....The Cobb AP with it protuned by a professional tuner is the real way to go. Work on your suspension, sways help a ton....I can't wait to install mine! Heres something else that helps.....TurnInConcepts short throw shifter set with the bushings.....talk about making shifts easier and much better.....you must try them out! Check their site: www.TurnInConcepts.com
Old 01-23-2006, 08:35 PM   #4
Car: 05 Subaru WRX STi
Fav Mod: FP Red and Meth
IWSTI Addict since: Mar 2005
Send a message via AIM to luSTI
+1 for TBE and AP.
luSTI is offline   Reply With Quote
Old 01-23-2006, 09:23 PM   #5
Car: 04 PSM STi
Fav Mod: Yakima Roof Rack
IWSTI Addict since: May 2005
Send a message via AIM to booSTi561
screw the intake, up-pipe, and bov, and get it protuned by Doug @ Top Speed. Or some other legendary shop... You will really then feel the performance.
Just get a AP, TBE, Fuel Pump, One Step Colder Plugs, a protune, and a short throw shifter. <---- u should be under $3k and have over 300 wheel
booSTi561 is offline   Reply With Quote
Old 01-23-2006, 09:58 PM   #6
Car: 05 WRB/Gold
Fav Mod: Hood Scoop Homer
IWSTI Addict since: Jul 2004
turbo back is fine, although i didn't know xs engineering made one. the APS 3'' is also very nice just to give you another option
accessport is great, but i wouldn't spend the money on the street tuner, and just have a professional tuner give you a nice and safe protune
the most popular intakes are probably the injen cai, the k&n short ram, and the injen cai. they aren't very important but they do add some power and will let you her the BPV
don't need a bov, most likely it will make your car run worse than normal
if you do all that you should probably have a little over 500 bucks left. i would suggest either springs or sway bars.
Old 01-24-2006, 01:22 PM   #7
thanks so i should get aps tbe cobb ap stg 2 k&n intake and what kind of rear and front sway bars? and would walbro hurt my car or make it better would the colder plugs even be necessary and what kind should i get of those?
Old 01-24-2006, 02:00 PM   #8
Car: 04 WRB Sti
Fav Mod: Turbo, more boost and more power!
IWSTI Addict since: Mar 2004
Used dp, mid pipe and ECutek cost me = 975.00 with labor included. This has been ultra reliable and fun. Yes I have a few more things done but this should give you an idea of a cheap alternative. I am running the stock axleback for stealth which is a bonus for a daily driven car!
V8killer2pt5 is offline   Reply With Quote
Old 01-24-2006, 02:04 PM   #9
Car: 05 WRB/Gold
those power mods sound fine, but if you want to be running as safetly as possible, get it protuned, so your map will be customed tuned for you car. as far as sways, i would go with the whiteline 27mm up front and maybe their 24mm in back. fuel pump wont hurt it, but it may not do too much untill you get an upgraded turbo (if you do). i've seen people make a little extra power with the colder plugs, but they certainly arent needed.
Old 01-24-2006, 07:44 PM   #10
Car: 05 STi CGM
Fav Mod: whiskey tango
IWSTI Addict since: Oct 2005
Just get the BOV, lol. Honestly the best way to go, like everyone else has said is TBE, AccessPort, intake of your choice (APS or K&N) and get a tune. You will be much faster and more happy than you might think. Get the BOV if you really want it.
Old 01-25-2006, 03:26 AM   #11
Titanium Member
Fav Mod: Bill
This sounds about right to me....might even skip the fuel pump.....talk with your tuner first.
Old 01-25-2006, 05:32 AM   #12
IWSTI Addict since: Jan 2004
1. TBE 1,200
2. AP 645
3. ALky injection kit 450
4. ProTUNE- 350ish
Edit: definitely gauges (and you don't necessarily need Defis)
Boxer is offline   Reply With Quote
Old 01-25-2006, 07:13 AM   #13
sounds good but id skip the BOV, ive heard that the stock ones on our cars are better than aftermarket unless your going for big big power
kxmx51 is offline   Reply With Quote
Old 01-25-2006, 07:20 AM   #14
Car: 04 WRB/ GOLD STI
Fav Mod: snail sticker = 5hp
IWSTI Addict since: Feb 2003
Originally Posted by Boxer
1. TBE 1,200
2. AP 645
4. ProTUNE- 350ish
I would also add:
5. one step colder plugs 40
6. Fuel pump 100
WRX_XB9R is offline   Reply With Quote
Old 01-25-2006, 12:49 PM   #15
so im thinking aps tbe 1200 cobb ap 650 protun aroudn 400 intake around 230 s203 cf lip 500 27mm front sway 24mm rear whiteline 450 is injection kit fuel pump and colder plugs really going to affect me? i mean i might do it just incase but im not sure yet
also anyone know of any good shops around tampa, fl
