Old 05-31-2006, 06:19 PM   #106
Meth Junkie
Car: Steel Gray 06 STI
Send a message via AIM to lennyk1313 Send a message via MSN to lennyk1313
Originally Posted by speedsnice
5th gear is closer to 1 to 1 ratio than 4th gear is, so 5th should be more accurate. 1 to 1 ratio is when your motor and wheels are spinning at about the same speed.
You are absolutely correct. My tuner made me aware of this right away. Many tuners will go for 4rth gear pull just to show higher numbers. I put 305WHP and 350WTQ in 5th gear, but wold have made easy 330/375 on 4th gear pull.
lennyk1313 is offline   Reply With Quote
Old 05-31-2006, 06:31 PM   #107
Meth Junkie
1. 06 STI
2. Base run Stage 2 270 WHP (fifth gear pull)
4. Base run Stage 2 283 WTQ
5. Protune Oct. 93 285 WHP (fifth gear pull)
6. Protune Oct. 93 310 WTQ
7. Protune Oct. 93/Meth 305 WHP (fifth gear pull)
8. Protune Oct. 93/Meth 350 WTQ
9. Down Pipe APS
10. Catback APS Catted
11. Engine Management AP stage 2 (Protuned 93/Meth)
12. Stock TMIC
13. Tony at XX Tuning
14. Dynapack
15. Location East Hartford, CT
16. APS CAI, APS Inlet, Walbro 255, Devilsown Methanol Kit
Old 06-01-2006, 12:25 PM   #108
Car: 05 Subaru WRX STi
Fav Mod: Reflashed ECU/TBE/TD06 20G
Originally Posted by BEEZ
1. 2004
2. NA
3. NA
4. 285 hp
5. 291 tq
6. Stock gutted with K/N
7. Helix Catless
8. Helix 3" Catless
9. Ecutec
10. Stock TMIC
11. Mike @ Gruppe-S
12. Mustang
13. CA crappy 91 oct gas
14. Deadbolt 20 g, 850cc inj, Walbro 255, tial 38mm EWG
I know that i have to run the crappy gas and its a mustang dyno which is very realistic (harsh) on numbers. But why do my numbers seem so low compared to other sti owners in this thread with stock turbos? i know that i could use a aftermarket intercooler.. but the tuning and A/F is solid! and I make power from 3k to 7k rpm.
If it makes you feel any better, I used same tuner, same dyno,same gas, and basically same set up, except I have Gruppe-S headers, Spearco TMIC. and no EWG and got 296whp/307wtq with safe tune with an '05 STI.
billg is offline   Reply With Quote
Old 06-13-2006, 06:53 PM   #109
Fav Mod: tein
Default Dyno Sheet for headers?
Does anyone have a dyno sheet or just know of how much power is gained with headers on an sti? Specifically non-equal length?
blustile2240 is offline   Reply With Quote
Old 06-18-2006, 07:15 AM   #110
Car: Slow 05 STi
Fav Mod: Loping Idle
1. 2005 STi
2. Basline HP - 307.6 [Stage2 modified ST map]
3. Baseline Torque - 328.22 [Stage2 modified map]
4. Final HP - 316.11 on 93 oct; 328.5 on 50/50 w/ 107 oct.
5. Final Torque - 346.91 on 93 oct.; 371.15 on 50/50 w/ 107 oct.
6. Intake mods - K&N Typhoon w/ RU2800 filter
7. Down Pipe - TurboXS Stealthback wrapped, catless
8. Axleback - Prodrive Round-Tip
9. Engine Management - Cobb AP StreetTUNER
10. IC type - stock TMIC
11. Tuner - Doug @ Topspeed
12. Dyno type - Dynojet
13. Location of Dyno - AR Fabrication, Virginia
14. Other mods -NGK colder plugs
100+ degrees in the shop so needless to say the car was really heat soaked and not holding boost, so I could have hit higher numbers, this was only 18psi on 93 and 19psi on the 107 mix (Torco Mach 107 sucks so don't get it as the motor octane is really 104 and doesnt allow for much more timing)
Old 06-19-2006, 06:07 PM   #111
1. Car Year: 2005
2. Stock HP: N/A
3. Stock Torque: N/A
4. Final HP: 404HP
5. Final Torque: 369
6. Intake mods: Custom Intake
7. Down Pipe: Custom Downpipe, catless
8. Catback: Invidia N-1 style
9. Engine Management: Cobb Access Port with a 91/100 octane tune
10. IC type: Perrin FMIC
11. Tuner: Mike@Gruppe-S
12. Dyno type: Mustang Dyno
13. Location of Dyno: California
14. Other mods: GT35R, 255lb Walbro, 720cc injectors, Blown motor mod(these numbers where all put down on a blow motor haha)
Pump gas:
Race Gas:
Soon to come:
850cc injectors
Custom Blow through MAF set up
Forged Motor(motor will be done by 6/23, then it's break in...after that I will have new numbers)
Retuned with more timing on 91/100 tunes and a c16 tune
GT35 STI is offline   Reply With Quote
Old 06-22-2006, 01:31 PM   #112
Car: 05 STI
Fav Mod: Utec
1. Car Year: 2005
2. Stock HP: 238 (different dynojet)
3. Stock Torque: 238 (different dynojet)
4. Final HP: 397
5. Final Torque: 401
6. Intake mods: Txs BigMAF
7. Down Pipe: Txs coated DP + catless cat back adapter
8. Catback: Greddy Evo2
9. Engine Management: Utec + WI
10. IC type: APS DR725 FMIC
11. Tuner: Doug@Topspeed
12. Dyno type: Dynojet
13. Location of Dyno: ARFab Virginia
14. Other mods: SZ55, perrin ebcs, 255lb Walbro, perrin injectors, WI 6gph@150psi
15. Boost 23psi
higB_0x05 is offline   Reply With Quote
Old 06-24-2006, 01:17 PM   #113
Titanium Member
Fav Mod: Bill
Great numbers guys! Keep 'em coming!
Old 06-29-2006, 08:34 PM   #114
Car: 06 Sti/White
Fav Mod: APS FMIC/HarmanMotive tune
2. Cobb stg. 2=275
3. Cobb stg. 2=284
4. 100 oct. tune=312
5. 100 oct. tune=355
6. Intake mods: Stock
7. Down Pipe: Cobb catted
8. Catback: Cobb
9. Engine Management: Cobb AP
10. IC type: Stock
11. Tuner: Dan Harman @ Harmanmotive
13. Location of Dyno: Torrance, CA
14. Other mods:Cobb pulley, Hypervoltge grounding,
15. Boost 19psi
Trifecta is offline   Reply With Quote
Old 07-01-2006, 04:54 PM   #115
Car: Skiing, Football, Lacrosse, Mountainboarding, Car, Girls
Fav Mod: Ski Instructor, Car porter, Mountainboad instructor (all seasonal)
Location: Snowmass CO (winter), Boulder (fall/summer), Chicago (spring)
Send a message via AIM to str8line86
2. ??
3. ??
4. 309.1 (91 pump)
5. 317.9 (91 pump)
6. APS 65mm CAI
7. Perrin 3" catless
8. Perrin 3" single tip
9. ECUtek
10. APS DR725 FMIC
11. 9 secon racing
12. Mustang
13. Boulder, CO. (5800ft)
14. Walbro 255, Ported wategate
--- done by the 20th, gt30r rotated, 860cc inject, alky---
str8line86 is offline   Reply With Quote
Old 07-02-2006, 10:18 AM   #116
1. 2005 STi
2. ?
3. ?
4. 323 whp
5. 355 wtq
6. clipped snorkle
7. 3" Helix catless
8. 3" custom (cheapo, alloy, crush bent, ebay carbon muffler 3" inlet)
9. Cobb Accessport with PDX's semi-custom protune map 100oct map
10. Stock
11. PDX
12. Mustang
13. Lousiville, KY
14. Light weight crank pulley (perrin)
-Stock VF39 @ 19psi peak
INNOVA is offline   Reply With Quote
Old 07-02-2006, 10:47 AM   #117
Car: x2 05 WRX STi's
Whats the lwpc? awsome #'s though. I am going to get both cars protuned on wednesday by pdx..
Sinister redlines is offline   Reply With Quote
Old 07-02-2006, 11:14 AM   #118
Car: 2004 Subaru WRX STi
Fav Mod: so far.... COBB ACCESS PORT FLASHED TO 91 OCTANE STAGE 2 OFF THE SHELF MAP using a Mustang Dyno...
Send a message via AIM to zeroGsti
1.HKS Downpipe *moded to bellmouth* Heat Wrapped
2.HKS Hi Power Exhaust
3.HKS Turbo Timer
4.Cobb 91 ocatane stage 2 off the shelf map
*On these dyno sheets I was running the Injen Cold Air intake and it was running a little lean when doing the base runs. Mike @ Gruppe-S told me just to put the stock airbox back and the torque would rise to around 285! He said it would be pointless to Protune the intake because it wouldnt really create power, it would just get rid of the leaning issue. It would be better to save the money and upgrade to a front mount intercooler,larger turbo,injectors and fuel pump then get it Protuned*
zeroGsti is offline   Reply With Quote
Old 07-02-2006, 11:14 AM   #119
Oh sorry, Light weight crank pulley.... no biggie.
PDX knows their stuff!
Old 07-02-2006, 11:35 AM   #120
Are you the same INNOVA on redlineforums.com becuase I sold my RL's for the STi's.
