Old 09-15-2005, 11:55 AM   #61
wdb
dances with roads
Originally Posted by RexMan
Well, this experiment actually hurt gas mileage in the long run.
I was very disciplined and shifted at 2500 when I could and ended up getting 16 mpg. That's about 4-5 mpg less than I usually get at shifting at 3500-4000 rpm.
I think it was because I had to use the boost more than usual at low rpm.
So...shifting at 3500-3750 rpm looks to be the sweet spot.
Wow, real world testing. Cool. Thanks for doing it and thanks for sharing the results.
Old 09-16-2005, 04:19 AM   #62
Car: Waiting for the STI
Fav Mod: Driving My Car
Well I am new here. I bought my STi 05 Silver a month ago. I must say that going from an 01 RS fully loaded to this is a different road.
Back to the post, for the break in period, I kept my self very constant at changing gear at 3k RPM, specifically as the manual stated. My milage was not that great I was doing about 260 Miles per tank - which is about 17 mpg.
Once I broke the 1000 miles, i went out and took the air silencer off. And this was a big difference. Keeping the same driving as before for a full week, just going to work only, where I do 64 miles back and forth. I only do 24 miles highway and then 8 miles back roads, and not going more than 75mph I managed to do about 330 miles per tank. Which is 22-24mpg, wich is a big difference.
Performance - none really, car is still all stock. Only change is the BOV music once you remove the silencer out.
I really do not know , if it is that as the car gets broken in more and more, the engine starts to work better. So maybe that could be the reason for such a jump in fuel efficiency.
Later,
sebtarta is offline   Reply With Quote
Old 09-16-2005, 09:56 AM   #63
Car: 05 WRX STI
Sebtarta? Removeing the silencer from the BOV, can this cause any problems? Where is this silencer located? Any pics?...
Donmei? Can our Sti's get a custom tune with out buying an EM system like the Cobb Access Port and still get added power? Are you also saying that getting EM like the AP will not only get us more power but also better gas mileage?
Old 09-16-2005, 02:26 PM   #64
Car: 05 CGM STi
Fav Mod: Genome
I believe Sebtarta is refering to removing the intake silencer, many people do this. I have a feeling his change in mileage is related to having the car completely broken in. Here is a link to the mod. More of a *sound* mod, but it's free
You need to pay someone to get any type of a tune. They come in the form of
  1. piggyback ecu (still uses stock ecu, just modifies certain signals coming into it, basically tricks the ecu)
  2. reflash (modifies the code in the ecu, setting different fuel/timing maps, etc)
  3. stand alone (whole new management system for your engine)
Accessport is probably one of the most popular methods, but you won't really get a custom tune from it. You would need to upgrade to the street tuner software that lets you modify the AP maps and fine tune for your setup. The AP is nice b/c you can do it yourself, the base AP can be used by anyone.
Read up on the different EM systems in the ECU Tuning & Performance Electronics forum
A tune will allow you to run leaner in certain situations where you are not at risk of harming your engine, while still giving the car the fuel it needs under heavy load/boost.
Old 09-16-2005, 02:37 PM   #65
Muller Chevrolet
Fav Mod: a new 08 STi
man i get like 15 mpg
i do like 200-220 a tank lol
when i was stock, i saw mostly 220+ only because i don't think i was on it as much.
Old 09-16-2005, 04:01 PM   #66
Car: 05 blue/gold
Fav Mod: bone stock
Default I went from 17mpg to 24.5 using this
I went from 17mpg to 24.5 using this:
http://www.scangauge.com/
It's literally paid for itself and then some. I drive 35 miles a day, as I drive I can see how my actions (shifting, accelerating, turning, AC, windows) are directly impacting the MPG's, and so, through trial and error, I've learned to drive in a manner which gives me the best milage given the conditions.
On a side note, all the other capabilities of this little device are incredibly usefull, the only down side is how gangly and ugly the box is, so I took a dremmel to it and installed it where the clock goes. It looks awsome, I wish I knew how to post pictures, I would show you guys.
TaoKane is offline   Reply With Quote
Old 09-16-2005, 11:18 PM   #67
Car: 04 WRB STi
Fav Mod: Trailer Hitch
tao,
Thats a neat device, and well worth what they seem to be asking.
But most people already have a "fuel economy gauge". In the '70s durring the fuel crisis, vacume gauges were all the rage. The idea was to keep the car running as muc vacume as possible.
Well, thats exactly what our boost gauge is. With my passat I was able to drive almost all the way to work and never exceed 5 in-hg of vacume. In other words it was possible to use the boost gauge as a fuel economy gauge. When you're in the boost, you're using fuel.
I didn't do it often, but when I was driving in traffic, it almost became a game to see how little manifold pressure I could use. It made me a better driver because if forced me to anticipate what traffic was doing and anticipate power needs well in advance. It also forced me to look as far down the road as I could see to help with anticipation.
I personally like having a needle for something like that rather than a digital readout. But for $129 that things a steal.
Don
donmei is offline   Reply With Quote
Old 09-17-2005, 07:21 AM   #68
wdb
dances with roads
Also there is the ProTuner package, through which professional tuners can custom tune your car and provide you with a map that can then be loaded/stored via the AP.
Old 09-17-2005, 07:31 AM   #69
wdb
dances with roads
Originally Posted by donmei
tao,
Agreed. Finally, someone asking a reasonable price for an automotive electronic gizmo. It basically appears to be an ECU signal interpreter, and as ECU's have become more and more standardized a tool like that one became more and more practical. I wish it had a bigger display though.
Funny you should mention it. Since I started this whole fuel mileage thing I've been paying more attention to my boost gauge during 'normal' (read: not going like a bat out of h*ll) driving. In particular I've been playing around with keeping the pressure under zero. Very handy, and one more thing to keep my from going bonkers while following the soccer moms in their SUVs.
Old 09-17-2005, 09:45 AM   #70
Car: 04 WRB STi
wdb,
that was the whole purpose of the OBD II standard. Standardized data formats for specific items that the govenrment considered necessary to diagnose problems with anything that could affect exhaust emissions. Prior to OBD II (and OBD I) everyone used their own proprietary data format.
Brand specific scanners can get down to items outside of the OBD II standards, like setting door locks, radio, alarm parameters. On a VW there are an amazing number of things you can tweak with these devices. Right down to how the auto trans shifts.
Don
Old 09-17-2005, 01:54 PM   #71
Car: 97,98,00 Subaru Impr
Fav Mod: STi Seats, engine mounts, door sills;)
Every time you add something to the "intake" the car needs to be reflashed because the factory ECU can not deal with it properly...at least I think this is true
ravent is offline   Reply With Quote
Old 09-20-2005, 04:31 PM   #72
Car: 01 Subaru WRX STi Sp
Default The first to e-mail me @
christian@cobbtuning.com about an economy map for their STi will get something to look at...and test.
Christian. is offline   Reply With Quote
Old 09-21-2005, 08:24 PM   #73
Car: 05 Darth STi
Fav Mod: Vishnu v370
i doubt i'll be the first to email you, but i'll try.
yeah, i have about 1500 on mine and get 18 mpg.
i've read elsewhere mod'n the fuel maps will not only get you hp, but get you a little more mpg; a win in both cases IMO.
racephysics is offline   Reply With Quote
Old 09-22-2005, 03:53 AM   #74
Car: 05 Subaru WRX STi
How about the ecutek dash http://ecutek.com/products/dashdisplay/
TampaSTI is offline   Reply With Quote
Old 09-22-2005, 06:26 AM   #75
Car: 04 WRB STi
If you just want real time monitoring of manifold pressure, a $50 boost gauge/pod combination is all you need. For use while driving, I like a needle because its movement can be picked up in your peripheral vision.
If I'm looking for exact data, digital is the way to go. each has its place
