Old 04-24-2005, 12:45 AM   #1
Default Ring Lands?
I've been searching around this website for the past few days and it seems that most people think that the STi can make 400+ Whp with a bigger turbo, but everyone says the ring lands won't hold. I'm not a car expert so I thought I'd ask here what exactly is a "ring land"? I'm guessing it's the piston ring or something but i'm not sure. Also, can you get stronger ring lands to avoid this situation?
nightfire is offline   Reply With Quote
Old 04-24-2005, 07:27 AM   #2
Ok thanks for the pics. So I guess the whole problem could be solved by just putting in forged pistons? If so how come everyone is makeing a big deal about it, if they want 400+ Whp and they have the money to do a fuel pump, injectors, turbo upgrade, and still drop a lot of money on tires and wheels then springing some money for forged pistons should be no problem.
Old 04-24-2005, 09:28 AM   #3
Car: 2004 STi
yes, forged pistons would help. People are complaining because they are people and people always need something to complain about. Especially in online forums. Also all the other markets with the 2.0L STi engine come with forged pistons from the factory.
They should be complaining about spening $500+ on a bling exhaust or $800-$1k on an intercooler. Many other Subaru parts are MUCH more overpriced than pistons.
I agree with you 100%.
Old 04-24-2005, 10:53 AM   #4
Fav Mod: driving lessons :)
Trader Rating: (12)
Default pistons
Nope. JDM V8 2.0L EJ207 changed over to hyperuetectic cast pistons, similar to ours. V7 and earlier models have the forged pistons. Supposedly the hypereutectic pistons are "stronger" (per SOA) but at the expense of being more brittle (and hence MUCH less detonation resistant). Either way, USMD STi's are making pretty insane power (more than 500whp) on stock internals. How long they last will depend on the quality of the tune (and appropriate ancillary hardware). From reading other's results, the majority of cracked ringlands seem to be from earlier attempts to upgrade the STi's power, when the aftermarket was somewhat lacking. Less and less ringland failures have been showing up, now that the appropriate aftermarket support is showing up and people are figuring out how to really SAFELY tune STis for big power. Of course, a good set of forged pistons may broaden the detonation resistance of the STi, but you can still destroy a built motor if your tune sucks.
gesundlich is offline   Reply With Quote
Old 04-24-2005, 11:25 AM   #5
How exactly has the tuning changed for the STi to make it safer? Different components or just tuning a stand alone system differently? Sorry for the noob question but I'm not to familiar with tuning STi's as you can see.
Old 04-24-2005, 11:42 AM   #6
Car: 2004 STi
the STi ECM was a major advancement over previous versions of the ECU. It employs two processor instead of one and different tuning parameter related to the AVCS, so the entire US aftermarket had to kind of start over to figure out the ECM as well as figure out how to tune for 2.5l and the new turbo. The things that worked before did not work as well on the USDM STi. It was simply a learning curve as geslundlich stated. Remember, the STi has now been in the US for two years now, that is a very long timeline for development. Significant knowledge has been gained and suitable engine management solutions now exist. If you look back at the early threads on this forum you will see that we had to figure out all the specs and details of the car before we could move forward. Even the basics like the block construction, piston matierals, turbo design, etc etc had to be figured out. The car was basically a black box that had to be analyzed and tested to figure out what would work. The aftermarket for the STi at that time was basically nonexistant and the only parts you could get were the parts that swapped directly from WRXs or generic peices like boost controllers. You johnny-come-lately really benefit from the guys who got the cars first and did all the investigation and work to support what is now available. It really has come a LONG way.
Old 04-24-2005, 11:53 AM   #7
Thanks for the info Xman. That's awesome how much has been figured out in the last two years. Do you think the US STi engine's capabilities will eventually surpass that of the Evo's 4G63? The 4G63 has been out for soo long that people now know exactly what works best on it so there isn't really any guessing. Since people are still figuring out the US Spec 2.5L engine it seems like we still have a lot to learn and we seem to be already breeching the power figures of the 4G63. Yes the 4G63 has an iron block but the STi has .5 more L of displacement. Sorry for the long post of saying the same think, I just wanted to get my comments/ questions across.
Old 04-24-2005, 12:02 PM   #8
Car: 2004 STi
no, the 4G63 cast iron block is just physically stronger than the STi die cast aluminum, therefore can tolerate higher cylinder pressures and therefore put out more power. I don't expect the STi to put out the same HP/L figures with the same durability as a cast iron block, but the EJ257 is impressive. Maybe some tuners will prove me wrong, but that is my take on the comparison.
Old 05-11-2005, 08:53 AM   #9
Car: my STI
Fav Mod: Sr. loan officer
Send a message via AIM to tuswm Send a message via MSN to tuswm Send a message via Yahoo to tuswm
Hey maybe crawford will come out with a 3.5L cast iron closed deck block with fully built internals aswell. Then I am sure we could surpass the EVO and the 996 TT while we are at it. Its just a matter or time.
There are some sick STI now on nasioc under proven power bragging.
tuswm is offline   Reply With Quote
Old 05-11-2005, 11:57 AM   #10
RiX
Car: Driving
Fav Mod: Driving school... GT35R :)
Hmmm 3.5L... yummy. Would you like biturbos to go with that?
RiX is offline   Reply With Quote
Old 09-11-2006, 11:22 AM   #11
Car: 04 PSM STi
Fav Mod: Stage 2 parts
Manual or even electronic boost controllers without adding fuel would be a great example. It took almost a year to get tunable engine management out for the STi with the drive-by-wire setup. I watched a buddy break ring lands with nothing more than an electronic boost controller.
ScoreBo is offline   Reply With Quote
Old 09-11-2006, 11:47 AM   #12
Car: '05 Subaru WRX STi
Send a message via AIM to anthongy817
Did he turn up the boost..?
I believe you would have to pull the shortblock to be able to swap in the forged pistons and that is an additiona $1500 in labor fees.
anthongy817 is offline   Reply With Quote
Old 11-28-2007, 11:02 PM   #13
Car: 06 WRX TR
Default Re: Ring Lands?
Yeah, could somebody post or send me the pics of the ring land. Im in the same boat as well, im pretty sure i have a broken ring land and all i got was a tune. I was told it was rather conservative.... (somebody remind me not to go back to that guy again...)
If anybody has any projections on cost of repair or tips for dealing with this would be greatly appreciated.
SubieSteve is offline   Reply With Quote
Old 12-01-2007, 05:51 PM   #14
Car: Silver 05 WRX STi
Fav Mod: POWER
Default Re: pistons
I agree 100%. STI internals are built for higher horsepower as long as the car is tuned properly. Basically, the STI is overbuilt to withstand the abuse to the car in rallying.
Phil 05 is offline   Reply With Quote
Old 12-01-2007, 10:09 PM   #15
Car: 07 WR Blue STI
Default Re: pistons
Rally cars use the 2.0 liter jdm block.
gOt_rally? is offline   Reply With Quote
