| Senior STI Driver | will any short ram w/ the silencer removed give my sti the spool up and recirculating sounds? I like it when it sound piss3d off.... This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #5 |
| S204 Racer Car: 04 WRB STi Fav Mod: Trailer Hitch Location: CT, U.S.A. Posts: 3,139
IWSTI Addict since: Feb 2004 Trader Rating: (0) | Both, They throw off the computer. Either without a s/w upgrade usually results in less power. Although some brands to this more than others. If you want the bling of the noise, fine, but expect to pay for it with a bit of real world performance. Don |
| | #6 | |
| S204 Racer | Quote:
i left mine in, and will take it out "someday"oh, and yes, it will give you all these pretty sounds ![]() Jurgen. | |
| | #7 | |
| S204 Racer | Quote:
neither do i dragrace at the track, so i have no *real* proof that it makes the car slower/faster/or no difference. but i can't really feel any difference. however, it seems to me that spool up is just a little faster. and i'm not sure if this is just my ears playing tricks on me, but since i have the intake installed, it sounds like my exhaust note has become slightly more agressive too. Jurgen. | |
| | #8 |
| Spec C Club Car: 08 CBR1000RR Fav Mod: None Location: Kansas Posts: 2,456
IWSTI Addict since: Jun 2004 Trader Rating: (6) | I've researched this subject tons. It seems to be a flip of the coin as to weather or not you will gain or lose HP with an intake installed. Turbo XS and K&N both have dyno charts to show that you gain HP with their intakes installed on the STI. We all know however, that dynos vary from run to run. Other people with these intakes installed will tell you that they ran slower at the track after the installation of the intake. If you do purchase one, make sure that it will not lean out your car. It needs to maintain the stock MAF sensor postion as much as possible. Be prepared to not be able to use your intake if you do any type of engine management. Most tuner companies set up their base maps using the stock air box. If you plan on having the car professionally tuned, then you may be able to use it. My 2 cents Jason |
| | #9 |
| Senior STI Driver | it just takes the ecu a couple of days to adjust 2 the diff air intake. And, ANY short ram will give me that piss3d off sound? um, and is there a orob w/ H2o getting in the cai becuase its mounted near the fender? dont want water in my engine ![]() -spyder This ad is not endorsed by this member. Please register or login to hide this ad. |
| Thread Tools | |
