Old 08-26-2008, 03:35 PM   #1
Car: 2007 SWP STi
IWSTI Addict since: Mar 2005
Default Blue smoke at start up
It happened today when I started it in the morning, It stopped smoking after 5-10 seconds. Has not happened again.
I have an '07 with 14,600 miles.
The last time the car did this was 3 or 4 months ago.
The car ran smooth today, I got on it and feels normal, the oil is full and there isn't any smoke coming from the oil filler cap.
Should i just watch it, see if it does it again?
The car is 100% stock btw. Stock tune.
Future/GDB/Driver is offline   Reply With Quote
Old 08-26-2008, 03:47 PM   #2
Fav Mod: I do meth...
IWSTI Addict since: Nov 2007
Default Re: Blue smoke at start up
Stock tune?
renns is offline   Reply With Quote
Old 08-26-2008, 03:49 PM   #3
Car: 2007 SWP STi
Originally Posted by renns View Post
Stock tune?
Stock everything.
Old 08-26-2008, 03:52 PM   #4
I has forged rod
Fav Mod: Invidia G200
IWSTI Addict since: Apr 2007
I wouldn't be too concerned if it happens once every few months. Keep monitoring it and see if it happens or frequently, or if your car begins acting differently. You should really get the AP and flash stage 1 though.. I would hope you are aware of the crap tune Subaru put on the 07's (and 08's apparently).
Old 08-26-2008, 03:53 PM   #5
Car: 2005 OBP STi
Fav Mod: CBE
IWSTI Addict since: Aug 2006
bring it in to the dealer and have then do a compression test and a leakdown test. you dont really want to take any chances with the 07's. it could possibly be blow-by, but at that mileage there shouldnt be too much carbon built up
johnlude85 is offline   Reply With Quote
Old 08-26-2008, 04:08 PM   #6
Car: 04 Sti Wrb on Silver
IWSTI Addict since: Jul 2007
Blowby is usually white smoke. If its excessive blue smoke you may have a ringland pooped or you would have puddles of oil some consequent of excessive blowby.
bluedemon_II is online now   Reply With Quote
Old 08-26-2008, 04:12 PM   #7
Car: 06 STi
IWSTI Addict since: Nov 2006
If you let the car idle for 5minutes after driving(fully warmed up), do you get blue smoke at idle? That is a symptom of a turbo seal/bearing issue. If you're stock, do what was mentioned and let dealer take care of it under warranty. No warranty, there is a host of things you can check on your own.
Old 08-26-2008, 04:15 PM   #8
Car: 2007 SWP STi
Well it looked blue, i saw it through that auto dimming rear view which is sorta green tinted when it dims inside my garage.
Old 08-26-2008, 04:16 PM   #9
Car: 2007 SWP STi
I'll drive it and let it idle tomorrow and I'll report my findings.
Old 08-26-2008, 09:32 PM   #10
Car: 2007 SWP STi
I drove it around I got on it and then let it sit for a while idling and no smoke came out.
And the times I have started the car up today quiet a few times, no smoke on start up.
Old 08-26-2008, 09:57 PM   #11
Car: 06 WRX STI
Fav Mod: Front license plate delete
Blow-by or oil level is too high.
crand002 is offline   Reply With Quote
Old 08-26-2008, 11:58 PM   #12
Car: UGM 07 WRX STi
IWSTI Addict since: Mar 2006
That sucks!
blownboxer4 is offline   Reply With Quote
