| Amateur STI Driver | well i just got my car back today from getting a new clutch and was just driving it around to break it in. I noticed that my cruise control light was blinking and my check engine light suddenly came on. I found the code and looked around differnt forums and found that leaking hoses or the intake could cause the problem. I looked under the hood and found that the cone on my iK&N cold air intake was not tight at all...so i tightend the clamp down and drove around for about 15 minutes and the code has yet to go away...should I clear the code with my AP or will it just go away over time? thanks This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #2 |
| I'm Jim Halpert
Car: 06 WRB STI Fav Mod: EWG Location: Irvine, Ca Posts: 6,793
IWSTI Addict since: Apr 2006 Trader Rating: (9) | reset ecu ftw! |
| | #4 |
| Amateur STI Driver Car: 07 STI Fav Mod: Coming Soon Location: Amarillo Posts: 33
IWSTI Addict since: Feb 2008 Trader Rating: (0) | po171 is bank 1 system lean, if your clamp was loose could have been having a vacuum leak after maf sensor and thinking it was running lean. clear the code and let idle for 10minutes. if light does not come back on then it is good to go. Rey |
| | #5 |
| Platinum Member Car: 06 STi Fav Mod: Buying a beater for DD Location: DE/PA border Posts: 1,151
IWSTI Addict since: Nov 2006 Trader Rating: (4) | My original protuner gave my car back and it threw that code. By the time I drove back(30mins) the turbo blew. Preturbo/intake leak somewhere. Car was LEAN. do you have a wideband gauge? |
| | #6 |
| Amateur STI Driver | no i dont...i have drove the car for about 2 hours in time today and the code didnt come back on and i havent herd any weird noises..its just a wierd time to happen because i just got my car back from the shop the same day they replaced the clutch. |
| | #7 |
| Muller Chevrolet
Car: 08 Chevy 2500 Diesel Fav Mod: a new 09 STi Location: Milford, NJ Posts: 10,206
IWSTI Addict since: Oct 2004 Trader Rating: (11) | just be careful when it's running lean. |
| | #8 |
IWSTI Addict since: Nov 2006 Trader Rating: (4) | Usually an intake leak of some sort will throw that code(could be intake or intake manifiold or pinched vacuum line). Find the problem and fix it ASAP. Loosen all hose clamps and reposition properly on intake and also look at all vacuum lines. Lean is bad. |
| | #10 |
| Amateur STI Driver | believe me im going to invest...if i did reset the ecu and the problem was still there wouldnt the check engine light come on again? especially after driving the car all day |
| | #11 |
IWSTI Addict since: Nov 2006 Trader Rating: (4) | It depends on the scenario. If lean at idle, prolonged/repeated idle will throw the code. If lean at throttle input, it depends on the input and how/when the ECU checks those paramaters. Mine was lean at idle and fine at WOT. It was preturbo. Made turbo overboost to achieve preset boost. So my gauge would show 20psi but in actuality, my turbo was boosting 24psi. See what I mean? TOO many variables to guess. But a LEAN CODE MEANS BAD THINGS. |
| | #12 |
| Amateur STI Driver | yea makes sense..so maybe i should let it idle for about 10 minutes to see if it throws it again...i would think that something this serious would make the computer keep sending these codes even after just being erased...i just hope nothing bad happens |
| | #13 |
IWSTI Addict since: Nov 2006 Trader Rating: (4) | Let it idle and listen under hood for sounds of a vacuum leak. Hose clamps are very easy to overtighten and this causes leaks too. |
| | #14 |
| Amateur STI Driver | i really appreciate you helping me out with this...I mean i would pay an arm and a leg for the dealership to look under the hood and say o yea it was a loose clamp...tomorrow i will let it run for a little while and if nothing happens then idk i will just have to go get a wide band gauge This ad is not endorsed by this member. Please register or login to hide this ad. |
| Thread Tools | |
