| Junior STI Driver Car: 2006 STI - Stage 2 Fav Mod: Invidia DP Location: Austin, TX Posts: 112
IWSTI Addict since: Feb 2008 Trader Rating: (1) | I put a few coats of high temp primer and high temp paint on my downpipe. Is it OK to wrap it with the header wrap as well? Or is it a one or the other type of thing? Anyone have that vendor link to the template on cutting the stock heat shield? Thanks. This ad is not endorsed by this member. Please register or login to hide this ad. Last edited by scrapiron7; 07-28-2008 at 08:31 AM. |
| | #2 |
| Junior STI Driver Car: OBP 2007 STI Fav Mod: Brake dust Location: Buffalo, NY Posts: 147
IWSTI Addict since: Dec 2007 Trader Rating: (1) | Do both wrapping and coating. For cutting the stock heat shield, check out COBB website, they have an instruction with downpipe installation. |
| | #3 |
| Authorized Vendor | Just dont wrap the cat. As far as the hi-temp paint, I am not sure about both that and wrap, I know if you do a true thermal coating you are not supposed to wrap along with it because then you can hold in to much heat and cause welds to crack, etc... As far as cutting the heat shield, just eye ball it and go for it with a cut-off wheel, its not to complicated. Dont cut off to much, you can always cut off more if you need to later on. This ad is not endorsed by this member. Please register or login to hide this ad. |
