Closed Thread
Old 07-21-2008, 07:24 AM   #1
Car: cgm 05 wrx sti
Fav Mod: 20g
Default oil in intercooler?
Well I pulled of my intercooler an the pipes an core have about a cup of oil in them. Any ideas where this is coming from?
kyle1984 is offline
Old 07-21-2008, 07:31 AM   #2
Fav Mod: Valentine 1
Send a message via AIM to boozy04
Default Re: oil in intercooler?
it's blow-by, and it's normal. a cup is an awful lot though, might want to check that out.
Put some catch cans on.
boozy04 is offline
Old 07-21-2008, 07:33 AM   #3
A.X.D.
Car: 2004 STi
going forward, please search the forum before posting. chances are, the issue you are having has been covered many times.
it is normal to find oil in the intercooler and IC piping. the STI returns the head and crankcase vents into the intake system.
also, if you run higher than stock boost levels, you will see more oil than "normal."
oil catch cans or air/oil separators will reduce or eliminate this.
Majin is offline
Closed Thread
