Old 07-19-2008, 06:28 AM   #1
Default Weird Power Curve :( Input please.
Guys,
Update on the car.
2004 STi dynoed on Dyno Dynamics. Car has been low on power (noticed at the Dubai Autodrome where I couldnt pull on NSX, 350Zs, E46 M3s and a stage 2 Evo would walk away from me Hard.
Anyways, the motor was replaced with a new block at 8K miles (currently 22K) and prior to the blown motor, the car made 315 to the wheels (tuned by Scott Seigal at SOG). I am under the impression that the dealer flashed it back to stock. Mods:
K&N drop in.
TBE w/ high flow cat.
Possibly a tune? Not sure.
Any ways, the boost guage does not show a spike and the boost is set at 1.1 bar through out. Thoughts? Possible issues as to why I have a flat curve?
Thanks in advance.
Regards,
Lutfy
Lutfy is offline   Reply With Quote
Old 07-19-2008, 06:31 AM   #2
Default Re: Weird Power Curve :( Input please.
Gota get the image hosted...itwont work from c:
Kilya is offline   Reply With Quote
Old 07-19-2008, 06:33 AM   #3
Fav Mod: Motor Mounts
Originally Posted by Lutfy View Post
Guys,
Update on the car.
2004 STi dynoed on Dyno Dynamics.[IMG]C:\Documents and Settings\Guest\Desktop\SDIM0251.JPG[/IMG]
Your going to have to upload it up to photobucket or photoshack etc.
Old 07-19-2008, 06:39 AM   #4
Dyno Attached (see below)
Old 07-19-2008, 06:52 AM   #5
Old 07-19-2008, 07:04 AM   #6
Muller Chevrolet
Fav Mod: a new 08 STi
what the ****!
Old 07-19-2008, 07:17 AM   #7
Banned
Car: 2002 Civic LX
Fav Mod: 30+ MPG =]
Send a message via AIM to STiSubyMan
I siad these words
"what the hell is that"
Please get tuned again or something...i do not believe that spike is good
STiSubyMan is offline   Reply With Quote
Old 07-19-2008, 08:59 AM   #8
Car: WRB EDM 06 WRX STI
Fav Mod: Aerys 3"
what are we seeing here? Knock correction? Could someone please explain, looks exteme weird
torquemada is online now   Reply With Quote
Old 07-19-2008, 09:07 AM   #9
Banned
Car: 2002 Civic LX
Fav Mod: 30+ MPG =]
Boost creep doesnt look like this does it?
Old 07-19-2008, 09:11 AM   #10
Car: 06 Aspen White STI
Can you show the timing and boost graph? It's cutoff in your picture.
Could just be a hiccup in the dyno?
jasonlee4180 is offline   Reply With Quote
Old 07-19-2008, 09:19 AM   #11
abracious
Fav Mod: Track time
poorly calibrated dyno. i'd worry about that tune if they can't even figure out the dyno. hp &tq do not cross at 5250.
Old 07-19-2008, 07:43 PM   #12
I am sure the dyno is calibrated right. Several Evos pulled some decent numbers. Its a PITA getting a decent Scooby Tuner here in Dubai. Not sure if someone else had seen this type of an issue or not.
I have the Tactrix cable (got it with me from the States). However I do not have the software which guages the, knock, boost, fuel etc. Any lead as to where I can download it from?
I'll be taking the car to the mechanic once I get the software. Thinking of doing an OTS Stage 2 Tune to keep things in check.
Frustrating....
Lutfy
Old 07-20-2008, 06:48 AM   #13
abracious
Fav Mod: Track time
Though now that I look at the left scale, you don't look like you're showing torque.
Old 07-20-2008, 07:01 AM   #14
Car: STIzzle
Fav Mod: Tint
That spike is definitely not being produced by your motor. Trust me...if you had an 80hp spike at 3600 rpm you wouldn't need a dyno chart to tell you something was wrong. I recommend finding another tuner or getting open source and learning how to road tune your own car.
Edit: What is the unit of measurement of the left?
Old 07-20-2008, 07:35 AM   #15
Car: 04 Sti Wrb on Silver
I had a similar problem with a car that i tuned, boost spiked up to 17psi and then dropped down do 14 psi all this before 4,000rpm. We found a faulty bcs was the culprit, we replaced with a stock unit and everything was fine. You can download the software from Romraider.com
