Old 07-18-2008, 01:29 AM   #1
Car: Silver 05 Sti
Default ARC Intake...
For a daily driven STI... Other than the stock intake... What would you guys recommended for the intake? What about ARC???
gerald32 is offline   Reply With Quote
Old 07-18-2008, 08:22 AM   #2
Car: Blue 04 WRX STi
Fav Mod: Brum brumm.. pop
Default Re: ARC Intake...
As far as I know the Cobb short ram with their airbox is the easiest intake to use since you can just use a Cobb AP map to compensate for the intake. I've heard many many good things about the APS 65mm cold air intake and APS turbo inlet but I'm still sketchy on wether or not a protune is required for either of those mods.
Either way you'll need engine management though.
SAx COLIN STi is offline   Reply With Quote
Old 07-18-2008, 08:24 AM   #3
NIИja
If you are just throwing on an intake, SPT makes one specifically for the stock MAF scale.
Otherwise, with another intake you will want to adjust the MAF scale to compensate for the rise/fall of air flow.
Old 07-18-2008, 08:29 AM   #4
Car: 07 SWP STI
Fav Mod: I-SPEED/Bride ZetaIII/Tein Flex
ARC is baller status.
funSTi is offline   Reply With Quote
Old 07-18-2008, 09:28 AM   #5
Teh Other White Meat
Trader Rating: (22)
sponge is not a good filter media. the ARC intake uses sponge filters. This has been proven in the past through actual formal testing. It will only filter large particles and let plenty of small particulate matter through.
For a DD, without a tune, keep the stock box and filter. Even a K&N panel filter has been shown to lean out the A:F.
Old 07-18-2008, 01:16 PM   #6
Car: 04 sti
Fav Mod: enginuity tuned
aps, aem, k&n, prodrive, and p&l if you're not going to be tuning for the intake.
