Old 07-11-2008, 07:55 AM   #16
Car: 05 STI
Default Re: Improved Oil Pickup Finished
Is there a recall for this part?
PSTi is offline   Reply With Quote
Old 07-11-2008, 08:04 AM   #17
If in doubt, flat out
Trader Rating: (23)
Originally Posted by WolfPlayer View Post
Wouldn't a new weak point now be the brazing where the tube meets the pickup? Why not replace the entire tube?
t
i agree. the oil probably dampens most of the vibration but it wouldn't hurt to tig both connections.
Old 07-11-2008, 08:43 AM   #18
Fav Mod: I like it all!
I understand your concern, but bigger is not always better, like I said in post #6. IMHO it's a system that will have vibration no matter what you do. The known failure point has been eliminated. The next weakest area is a guess on anyone's part, and likely significantly stronger than the original failure point. If anyone can prove otherwise I'm all ears. I apprecaite the feedback and support!
Thanks
Chris
sti_rules is offline   Reply With Quote
Old 07-11-2008, 12:39 PM   #19
Car: 2005 & 2008 STI
Fav Mod: UR 35R and Hydra tune by Scott Siegel :)
Send a message via AIM to JDM-STI Send a message via MSN to JDM-STI
I'll take one right now! Are you selling these?
JDM-STI is offline   Reply With Quote
Old 07-11-2008, 01:47 PM   #20
Moderator & ECU Tech
Fav Mod: mo boostaz
Originally Posted by TheLimitedProject View Post
No brazing. TIG welding.
I'll let him take care of his own thread now.
Not true. He tig welded the new tube to the flange. However, the tube is still brazed at the pickup. He left this stock.
t
Old 07-17-2008, 08:49 PM   #21
posted on E_bay... Search for STi or Legacy or WRX pickup.
Old 07-17-2008, 09:20 PM   #22
Car: 2007 STI
link:
eBay Motors: Subaru Impreza WRX Legacy STi Oil Pickup (item 170241089045 end time Jul-24-08 21:19:59 PDT)
jagstyle is offline   Reply With Quote
Old 07-19-2008, 09:05 AM   #23
Holy long thread!!
Please PM me with your interest and for details on my pickup.
Thanks
Chris
Old 08-01-2008, 08:20 PM   #24
Finally getting around to putting on my improved pickup this weekend. Pulled the old one out and inspected it thoroughly with a 17X eyeloop (no microscope handy) and it apears there is an area with some light surface cracks. Some look to be only into the braze flux, but a couple are definitly deeper. If anyone wants full resolution pics PM me your e-mail address. Once I get my super pickup installed I am going to polish the factory one down to see if the cracks penetrate the tube. If all goes well I will get vendor status so I can help everyone out with this horrible flaw.
Chris
Old 08-02-2008, 05:32 AM   #25
Not to ask a noob question but which STI's are these failing on?
up to 05 or later models as well?
skyline8409 is offline   Reply With Quote
Old 08-02-2008, 08:25 AM   #26
All of them. Some years are worse than others, but there have been failures on WRX, STi and Legacy models.
Old 08-09-2008, 06:14 PM   #27
Installed my pickup. It is rock solid and fits well. Before I put the pan on I used some clay to measure the distance to the botom of the pan to the pickup. It was VERY close, so I deshouded the can to increase the height height and open it up some. I know, I've always said there's no reason to deshroud because it's not the smallest hole in the system and the closer to the bottom the less likely to starv the pickup. Well after measuring the tiny clearance and observing the inside of the pan, the oil really has nowhere else to go except into the pickup (no matter how hard to you corner!). Baffles in the Moroso unit makes sense though because it's bottom is wide and flat. Feels good knowing I never have to worry about pickup failure.
Perfect pressure!
Old 09-04-2008, 02:50 AM   #28
for anyone's viewing pleasure...
Upgraded Oil Pickup Tube - Engine Rebuild and Upgrade Center
Old 09-04-2008, 07:31 AM   #29
Yup, those are the ones I saw in person.
[Nhat], there is the source
Tgui is offline   Reply With Quote
Old 09-16-2008, 02:00 PM   #30
pretty not bad
