Old 07-08-2008, 04:33 PM   #1
Car: 07 SWP Sti Limited
Fav Mod: Stage 2, Perrin cbe
Default is this a boost leak?
I just installed my electric prosport gauge and know I have a weird noise that almost sounds like a rattle but not exactly and I also hear a whistling whereas I did not hear it that loudly before I installed it. Could it be a leak where I cut into the vacuum line off the the bpv?
ps- I am ots cobb stage 2 and it peaks around 17.5 ish
07stilimted is offline   Reply With Quote
Old 07-08-2008, 09:19 PM   #2
Car: 06 wrb/gold STi
Fav Mod: g200
Send a message via AIM to futurestiguy
Default Re: is this a boost leak?
I have that noise also, my car didnt drive differently so i'm thinking its normal. I can only hear it if I have windows up and no radio on. Not sure tho, maybe i have boost leak also lol
futurestiguy is offline   Reply With Quote
Old 07-08-2008, 09:35 PM   #3
Car: 06 STi
Put some zipties on the T for the vacuum lines. Mine leaked until I did this. It would make boost fall off dramatically. If your hitting target boost and normal taper, you're fine.
