Old 07-07-2008, 01:24 PM   #1
Car: JBP 04 WRX
Default is rasp normal from a gt spec header?
i just installed a wrapped gt spec gen 2 unequal length header and uppipe onto my sti. it already has a catless downpipe and catless/resonatorless catback (invidia n1 race.)
now when hi rpms or low rpms in 1st and 2nd gear it sounds raspy, it sounds like cars flapping. i hate it! is this normal from this header? or is it because the car doesnt have a resonator? i know it was fine before this install. its embarrassing getting on the gas so i never do anymore =/
if it is the resonatorless catback, im probably going to get the street version of the same catback which has a resonator. or does anyone have recommendations for another very throaty, deep catback that has the canister look?
adWRXi is offline   Reply With Quote
Old 07-07-2008, 01:25 PM   #2
Car: '05 WRB STi
Fav Mod: Open Downpipe
Default Re: is rasp normal from a gt spec header?
A flapping sound usually indicated a leak somewhere in the system. Might want to check all your connections
Evan is offline   Reply With Quote
Old 07-07-2008, 01:27 PM   #3
Car: JBP 04 WRX
ahh are you serious?? i just paid a guy at a shop to check for leaks !!
its coming from the back of the car tho.
also, i had a bad launch the other day and i heard a "sputtering air" sound coming from the front. thats a for sure leak yea? im definetly going back tomoro.
Old 07-07-2008, 01:31 PM   #4
Car: '05 WRB STi
Depends, did you're rpm's jump when you heard this noise? Did you reach target boost when you heard the noise?
Old 07-07-2008, 02:03 PM   #5
Muller Chevrolet
Fav Mod: a new 08 STi
exhaust leak, most likely from the header.
use remflex header gaskets, they'll seal way better with your gt spec header. that's what i'm using with my gt spec.
Old 07-07-2008, 02:32 PM   #6
Car: JBP 04 WRX
well i had my vf39 p&p and a bigger tmic put on at the same time as the header/uppipe. i used to hit 18.5 psi but now it only gets to 14-15 psi. it DOES hold though.. and nothing acts funny, its all still ok. so i dunno..
i hate leaks.
Old 07-07-2008, 02:43 PM   #7
Car: '05 WRB STi
From the sounds of it, you have a boost leak and a header or up-pipe leak. As for your boost, connect your AP if you have one and look at your wastegate duty cycle, if it's closed ALL the time that means you have a boost leak and the turbo is working as hard as it can to get you to your target boost
Old 07-07-2008, 03:45 PM   #8
I almost have the exact same setup, except my Cat-back is the Invidia Titanium. The exhaust is raspy when it's cold. (Muffler) But, once the actual muffler warms up, the raspy, 4 - banger noise is gone. Does the raspy sound persist after a good 10-20 minutes of driving?
CarJway is offline   Reply With Quote
Old 07-07-2008, 04:03 PM   #9
i eat cones
Fav Mod: 18x8
Trader Rating: (16)
yeah, definatly sounds like a leak...
and, non-res could be raspy, not sure though.
Old 07-07-2008, 08:29 PM   #10
Car: JBP 04 WRX
ya the rasp is really bad when you first turn the car on. after it warms up, its pretty much gone. ive also noticed that there is barely any rasp if i turn on defrost of a/c.
if there was a boost leak, wouldnt full boost be unstable? because this holds.
Old 07-08-2008, 07:32 AM   #11
Muller Chevrolet
it can still boost, but it won't be boosting the correct amount.
Old 07-08-2008, 07:55 AM   #12
Car: 04 Sti Wrb on Silver
If you have a boost leak you will still boost but maybe no hit target and the air will be a lot hotter from the turbo working harder to reach said boost. Use oem Gaskets on all your exhaust parts and have them torqued correctly.
I have never heard a raspy subaru before if it sounds like a honda, id do anything in my power to fix it .
Old 07-08-2008, 11:33 AM   #13
Car: 06 sti blue
my car is the same.real rapsy at low rpm/ or partail throttle.wot it sounds bad ass.i have an ebay (edge) header.i know its cheap but for the price and performance its deff worth it.me and my buddy have both had them for over 2 years w/ no problems or cracks like many other pricey headers out there.but we both thought we had exhaust leaks too.but there both leak free.i myself am not a fan of the raspyness though.
my94saleen is offline   Reply With Quote
Old 07-08-2008, 11:45 AM   #14
Fav Mod: The Newest One!
i hate leaks.
def sounds like a leak to me as well. I installed my Maddad headers and UP. The sound changed some, but I only lost about .5psi. I talked to my tuner and he said this is normal when you swap to aftermarket headers. I have had my tune and I am running about 19psi right now.
Even on a base Stage 2 map, 14-15psi sounds way low.
